MT 4 1/2
MT 4 1/2
Home Forums Beginners questions MT 4 1/2
Viewing 25 posts - 1 through 25 (of 37 total)
  • #560085
    Me.
      @me1
      In need of a MT 4 1/2 adapter for my Harrison 140 – looked for ages on the net for one to turn up but as its such a stupid incomprehensible size seems impossible to find – I'm still trying to work out why Harrison used such a stupid size the 140 -but can't do much about it…..
      I'm going to make my own as a project so was wondering if any had done tis and any tips or tricks… ?
      Me.
        @me1
        #560086
          The opening paragraph of this explains the why : **LINK**
          http://www.edproject.co.uk/MT45adapter.html
          … and he then proceeds to describe the how.
          Pete.
            @pete-2
            Something I thought about a little while ago as my lathe uses this taper.
            A company I approached seeking to have obsolete collets made is D&J WORKHOLDING they offered to make me obsolete collets for £50 each, they may well make you one but as to be expected with one off orders won't be cheap, they are very good to deal with, I have purchased things from them in the past.
            #560089
            duncan webster 1
              @duncanwebster1
              There must be hundreds of lathes with MT4.5 headstocks, and when they pass from industry to private hands the adaptor bush always seems to go missing, probably because it is only used for between centre turning so is kept in a cupboard somewhere. An opportunity for Ketan to get a batch made?
              #560102
              DC31k
                @dc31k
                Rather than complimenting Harrison on their forward thinking, for giving you a lathe with the smallest taper that will accept the ubiquitous 5C collet, you curse them. Surely, your ire is better directed at the previous owners who have misplaced the bush.
                The 'explanation' in the link above is rather wishy-washy and the 5C reason has some sound engineering behind it.
                If you have Harrison on your naughty list, you can add Boxford (11-30) and Colchester (Chipmaster) to it. As these lathes have the same spindle taper, bushes may be available from them. See:
                https://www.model-engineer.co.uk/forums/postings.asp?th=87430
                and the 600 Group website.
                If you have any US connections, the bush is available from Grizzly:
                https://www.grizzly.com/parts/grizzly-spindle-sleeve-mt-4-5-mt-3/p97302912
                You might investigate which machine in Grizzly's product line the bush fits and see if the equivalent model is available in the UK with Axminster or Warco or Chester paint on it.
                If you consult this page, http://www.tools-n-gizmos.com/specs/Tapers.html you will see that 4 1/2 Morse has the same taper as 7 Morse, so that might be a source for a set-up gauge to make your own.
                #560103
                Richard Millington
                  @richardmillington63972
                  Boxford X10 series also use them:
                  X10-02-052
                  HEADSTOCK REDUCTION SLEEVE
                  £89.27
                  #560108
                  gary
                    @gary44937
                    me. if you let me have the measurements i might have one which was bought in error for my harrison m250.
                    #560121
                    Bob Worsley
                      @bobworsley31976
                      Also used in the L5A lathe, and I haven't used mine since I bought it in 1987.
                      Didn't know it was called mt4.5 or that a 5C collet would fit, must lead a sheltered life!
                      #560135
                      Me.
                        @me1
                        Posted by gary on 28/08/2021 09:18:28:
                        Thanks for the offer – I will let you know the measurements later.
                        disgust A 5C collet has the same dimensions – am I reading that right ?
                        #560144
                        DC31k
                          @dc31k
                          Posted by Me. on 28/08/2021 13:05:57:
                          Not quite.
                          A 5C collet is too big to fit within the outline of a 4 Morse taper.
                          A 5C collet fits within the outline of a 5 Morse taper. However, 5 Morse sets a lower limit on what the spindle bore can be, and thus the spindle bearings and also the spindle nose (chuck fitment) that can be put on the lathe.
                          All these things, especially the chuck fitment, add to the cost of the machine. The necessity for bigger chucks to fit the bigger spindle nose can limit the maximum rpm at which the lathe can spin.
                          4 1/2 Morse was used by the manufacturers as it is the smallest Morse taper within whose outline the 5C collet will fit.
                          On your Harrison 140, if it had a spindle with a 5 Morse taper in it, I suspect it would need the next size up L- nose on it. Similarly, on the Colchester variant, the 4 1/2 Morse allows a D1-3 nose, rather than D1-4.
                          #560174
                          Me.
                            @me1
                            Like a fool – I thought that would be an easy thing to do – as I don't have anything to measure I can't send you the measurements …. Doh….
                            From the chart the 4.5 MT is 1.5" on the gauge line – down to 1.266" – over a length of 4 1/2 inches – 0.6240 taper per foot. Hope that helps and PM me with the details – if you want to part with it.
                            #560289
                            Me.
                              @me1
                              Have had positive result from a generous member – but, it might not be what I need – we are going to investigate if it solves my problem.
                              If not – and as its such a thing that loads have lying around and don't often use – is there any one else out there that would want to part with a MT4.5 taper insert….
                              #560291
                              Tony Pratt 1
                                @tonypratt1
                                Do you need one or just want one?
                                Tony
                                #560293
                                Michael Briggs
                                  @michaelbriggs82422
                                  I need one for my Harrison M250, I have created a "Wanted" Ad but it hasn't appeared yet. I don't know if I have created the ad correctly, it is the first time I have used this service.
                                  #560299
                                  Me.
                                    @me1
                                    Posted by Tony Pratt 1 on 29/08/2021 14:24:19:
                                    Tony
                                    I need one because i want one ! – In my eyes that's the same thing….. I'm sad like that….. its like having a Porsche 911 turbo and not having a whale bone fin…..
                                    #560300
                                    Tony Pratt 1
                                      @tonypratt1
                                      Posted by Me. on 29/08/2021 15:38:01:
                                      Tony
                                      That's OK you can never have too many tools or too much tooling.smiley
                                      Tony
                                      #560345
                                      davidk
                                        @davidk
                                        Posted by duncan webster on 27/08/2021 23:45:32:
                                        If Ketan were to have a batch made, I would certainly buy one for my Boxford 330!
                                        David
                                        #560346
                                        John Paton 1
                                          @johnpaton1
                                          4.5MT is also used on Boxford VSL headstock. Boxfords produced an adapted sleeve for 5C collets as well as a reducing sleeve but these are now out of stock and apparently not being remanugactured.
                                          I have a 5C adapter but would buy a 3MT reducing sleeve if they were hardened and ground and available for under £30.
                                          I believe there are a number of VSL owners who would want one too as this issue has cropped up in the Boxford User Group in the past.
                                          on the VSL the 5C adapter is a bit more complex but that is off topic so let's not get drawn into that here.
                                          Edited By John Paton 1 on 29/08/2021 22:15:54
                                          #560363
                                          DC31k
                                            @dc31k
                                            There's lots of talk about getting someone else to do the running around to have these remanufactured and then the first indication of price above is a mere £30.
                                            A healthy dose of reality is needed.
                                            What size should the batch be? Let us guess at 100.
                                            So, if sold at the price suggested, that nets £3000. Let us say 100% profit for the seller: £1500.
                                            How long will it take for the stock to be exhausted? There will be an initial rush to buy them when finished. Let us guess at 50% sold within a month. Then how long for the rest? They will be hanging about for a year or more. And then once they are sold, the producer will have to deal with two or three enquiries for one for the next ten years.
                                            How does the manufacturing take place? Where is the sample to come from and at what cost? Who has the measuring tools and skill to drive them to reverse engineer it? And to convert those measurements into an engineering drawing? What cost for the reverse engineering and drawing?
                                            All this and more for just £1500 a year?
                                            Anyone who wants one can make one. Buy a 3MT test bar (parallel round bar joined to a male 3MT) and set it up in a four jaw so the taper runs true. Buy a 5MT to 3MT open-ended reducing sleeve. Buy a couple of PCD inserts, set your compound to the correct angle and have at it. The hardest part of the process is feeding the compound smoothly enough by hand.
                                            #560377
                                            Me.
                                              @me1
                                              Thanks for the detailed synopsis – but not sure where the £30 price tag came from – nearest ive found are in the USA and he wants $120 each – and they are made to order rather than mass production which we all know for the community we inhabit is too small to sustain over manufacture of rarely used items
                                              I have no problem making one – but wanted to know if anyone had a spare or unused item they wanted to sell before I went down the manufacturing route…
                                              #560387
                                                Posted by John Paton 1 on 29/08/2021 21:57:30:
                                                @ 'Me.' for info. ^^^
                                                John Paton 1
                                                  @johnpaton1
                                                  My figure of £30 was based upon cost of a 5 to 2 MT reducing sleeve bought from RDG Tools in 2019 for £15. Basically I would be prepared to pay twice that sum for a smaller sleeve and suspect there would be a good number of others like me who would pitch in quickly to buy one at that price level.
                                                  #560728
                                                  John Paton 1
                                                    @johnpaton1
                                                    Right guys and gals, following this thread I have done a bit of research and the two 'discount' UK suppliers of sleeves will not be getting 4.5 taper sleeves even if we need a batch of them.
                                                    I have however spoken to a local precision engineering firm who can machine down a small batch of 5 to 3MT sleeves to 4.5MT (actually to match the taper on my original Boxford VSL collet adapter sleeve so I know it will be 'right&#39
                                                    It will be CNC turned using carbide tooling and he has quoted a 4micron surface finish which I am sure will suffice or needs.
                                                    The internal bore (which takes the wear) will be as supplied by the importer.
                                                    I will put an advert on this site when they are done which will be at the £40 / £45 mark if I find I have extra costs to carry but for those who contact me now wanting one 'for sure' I will be letting them go at cost which should be the magic £30 plus postage.
                                                    Lead time on machining will be 6 to 7 weeks.
                                                    Please PM me quickly / over the next week if you want one (or how many) as this will be s strict;y limited batch and `I shall be making the same offer on the Boxford site.
                                                    Basically I am doing this at cost to try and help fellow Boxford VSL users.
                                                    If others know of Harrison etc users who need 4.5 sleeves please pass on the message.
                                                    #560881
                                                    Me.
                                                      @me1
                                                      Thanks for doing this. Thats great news.
                                                      I have PM'd you already.
