As Ches says the main advantage is the system avoids creating a mix of flammable dust and air. Dust explosions were first studied in the UK in connection with coal mining, where it had been noticed that shot firing or a relatively small gas explosion occasionally resulted in massive explosions, sometimes ripping through miles of tunnels. The initial bang lifted and mixed fine particles of adjacent coal dust with air, that in turn ignited violently. The resulting flame front accelerated through the mine until it ran out of air or dust. Once the mechanism was understood, the danger was much reduced by keeping dusty tunnels wet, by balancing dry stone dust on beams that would be knocked into the mix and dilute the flame, and by keeping the mine clean. (Not sure how you keep a coal mine clean!)
Dust explosions are also common in flour mills, grain elevators, and similar industrial processes were fine dusts can mix 'just so' with air and be ignited by a spark.
The surprising thing is materials that are normally difficult to ignite are dangerous in dust form. A bag of flour is reluctant to burn, yet the contents produce a spectacular fireball if scattered up through a flame with compressed air. Don't try it indoors!
The Olds Elevator stops dust and air forming an explosive mix and keeps the building clean. Other methods of moving materials are likely to scatter dust where it might eventually become dangerous by mixing with air. Like a flame front driving through a coal mine, a small fire in a grain elevator can lift and mix dust into an explosive mix with air.
Simple yet no one else thought of it before. Genius!
Edited By SillyOldDuffer on 08/11/2022 10:55:22
