On
8 September 2024 at 14:35 Bazyle Said:
…some experience of sliding things up scaffold planks
Looking at the pictures of machines online, they seem to be on a decent steel base.
Remove overarm and knee/table from machine. Bring it as close as you can to the car and then span a sheet of plywood between top of steel cabinet and boot. Undo securing bolts and tilt it sideways onto the plywood. Slide into boot.
You may end up actually going downhill that way.
What I am saying is that if the machine is currently higher than or level with your boot, do not go any lower with it as if you do you have to regain that height by grunt power.
You can refine the basic setup: tilt onto a padded surface (old sofa cushion), have another sheet of something on top of the ply to make sliding easier, perhaps tilt forwards with a chock to make up difference between front of base and face of column. If the boot has plenty of headroom, build it up inside the car so there is no significant lip when entering or exiting.
