It might be useful to know more details of the problem – thickness, load, blind or through hole, diameter, etc. All may have a bearing on the problem.
Morris Marina hubs have been routinely altered, by plugging and redrilling, to change the PCD from 3.75” to 4” for different sized wheels. Usual, I believe, is to fit a flanged steel plug so that required strength is maintained and redrill on the required PCD . They are plain holes, of course, with the new wheel stud bearing on the flange of the insert.
A threaded insert, as Perko7, would usually be better than a plain plug, I would think?
It might be simply a case of drilling deeper, before fitting a plug, if it is a threaded hole.
Edited By not done it yet on 14/07/2020 08:30:02
