Posted by Nick_G on 30/10/2015 10:40:33:
OK I will add to this thread with a question.
I understand how centrifugal force works. But I am informed that when a motorbike is cornering it is centripetal force that keeps the machine and rider (hopefully . ) shiney side up.!
I have tried google to understand this but TBH it goes over my head. Can anybody explain to me in dunce type language how centripetal force works.?
Cheers, Nick
Years ago I crashed two times, no slide, but I could not explain what went wrong, both on corners.
I read on a magazine steer left go right, but that was not enough so I investigate.
This is my theory and maybe it can help.
You have to take the following factors in mind: Your mind &/versus body reflexes
1-Its a single track vehicle.
2-The Steer Left-Go right thing….(The excact wheel science is not important other than deeper understanding)
This is not the same as old term countersteering(Slow) like you see in stock car racing, however I believe the same can happen to a car if it travels fast enough with only 2 wheels on the ground.
—–0-10Km/h as you push steer it.
—–10-20Km/h a sort of dead zone.
——Over 20Km/h if you push the handlebar left the bike goes to the right, no matter where you lean or your passenger, this can be a powerfull force as illustrated by Sidecar cop shows. In this regard a sidecar can be a nightmare as it shape shifts in a corner.
3-You body reflexes:
——If you dont panic in upcoming situations, you will go as you planned by leaning the motorcycle or whatever you think you do to go around a corner.
——–If you panic, you were too fast, you were not paying enough attention whatever, your refkexces kicks in to defend you, however you may be "born with a car steering wheel in your hand", and the next 3 seconds of operation to the handlebar may be wrong, causing you to go where you try to avoid.
4-I took me 3 months of practice every day to change my relfexes so if I panic I pull the handlebar in the opposite direction.
5-How do you know I am not lying——Have you ever get near the pavement or a slight corner with your motorbike or bicycle, and get that enormous feeling like in a dream, you cannot get away from what you trying to avoid-?=If so your reflexes are wrong ….and may get you killed in head on colitions with oncoming traffic, you want to steer between the car you pass and oncoming vehicle, but you cannot get it in that gap, you got 3-5 seconds and if wrong your body get confused and cannot correct because you are in a reflex condition, it difficult to remember these few seconds.
Think about this, you probably won't move the handlebar the higher the speed, however its the direction of torgue your hands/arms apply to it, in reflex condition you dont think, body just acts fast or sometimes freeze if no time to react.
So its not as easy as telling somebody you should steer left to go right, you have to get your reflexces right, thats when it matters and its unlikely you get it embedded in one day practise.
I dont think theres an easy selution to this for most.
Note:To further prove you can change a reflex, I usually twisted my anckle with pain, so around the same time as this, I practised if I step on one foot the wrong way, I relax that side, so it does not put pressure on the wrong move and worsen the problem, and since then I never twisted an anckle again, and it worked.
I have seen videos of motrorcycole racing drivers that was killed by incorrect steering reflex with much space to spare. Knowing about it is not alone good enough, you must have the reflex working correct.
With this in mind rewatch videos motorcycle or bycicle accidents that looks like steering accidents, you have to watch carefully those few seconds….Interesting.
