Interesting how far this has gone in only a few days..
I was working in Honda/Yamaha/Triumph/MZ/SILK dealers then moved across the street to Suzuki/BMW/Vespa (?) dealers. (later dropped BMW, didn't want to be a 'boutique' dealer before it was even invented) Did a bit of work on the K series, 750 was quite a nice bike and K100 would do crazy high miles (one customer did about 245,000 )
Switched back and forth every few years as general managers believed they didn't need me to run things after I got workshops running properly.
I have 'first hand' experience of majority of the bikes mentioned (nearest Kawasaki dealer was 20+ miles away so did quite a few of those as well.)
Suzuki GT750, wasn't just fork 'problem' the swing arm was incredibly flexible, it was just a bad design and would wallow around even when in good condition (probably the real reason it was called the water buffalo?)
Always found CB750 too wide and heavy the extra torque was Ok but dragging bits around in corners limited it's use for me, my 591cc CB550F1 was much better for all around use
Also had 550's F2 and K3 ( 550FourK ) at the same time (still have original 1977 F1 don't remember what happened to the others, my brother had the FourK for several years.
Really don't remember much about FJ900, 'we' sold a couple but the earlier XS 1100 and later FJ1100 were much 'nicer' bikes for hooligans (anyone remember the 'Martini Yamaha XS1100?) that was a lot of fun as you could drift it very easily in second gear and have it completely sideways at 50~60 mph.
Sold a lot ofYamaha 600 Diversion but GSX-R was mainstay at dealers
Early-mid 80's after the GSX-R 750 was launched was when things got worse rather than better. Apart from cost cutting, the 'weight savings' using less material became a selling point.
The 'Sport Tourer GSX-F (later Katana's) were a much better handling bike with the perimiter frame but were way too heavy (particularly the GSX600F) 750 top end was direct swap as bore spacing and crank main bearings were same on all model SACS motors (even 1100 and later 1200 Bandit)
(plus, I have a 750/600 motor 'in the shed)
Little bit of modification though and even 600 was Ok to about 135., 750 was good for around 155 (it was most powerful 750 on the market at the time – below 10,000 rpm) All the sport 750's were more powerful but had to be revved harder
That's all for now, been breaking stuff in workshop although welded parts are not quite as tough as if they were made from chill cast steel then 'repaired' by being built up with MIG (no after treatment or normalising) Surprised how hard even A36 gets though.
