Take a look at my albums, there are some bike photo,s and restoration stuff in there. I'm currently working on an interesting project using castings rescued from a well known British Manufacturer at the time it shut down.
Not exactly bikes, but vehicle restoration, here are a couple of half shafts for a Humber car. They are almost finished, keyways to cut, keys to fit and oil throwers to make and fit.
The hubs that fit onto the ends of the shafts are in a repaired condition and I wondered why one had a thinner key than the other. It wasn't until I went to try the hub on the shaft while cutting the taper that I realised that one of the hubs must have been damaged and the taper had been re-cut, hence the larger diameter bore. Fortunately I tried the hub on the shaft while I was cutting the taper and realised its was,t quite the same as the first one I tried.
The splines were cut on my CNC mill and when finished required just a few minutes work with a file to ease the corner radius at the root of each spline to enable them to fit snugly in the diff.
Some of you might guess the Humber connection if you look at the pictures in my albums or you are a long term subscriber to Real Classic.
Edited By Bob Rodgerson on 15/09/2016 11:04:58
Edited By Bob Rodgerson on 15/09/2016 11:06:59
