Presumably you have already checked that a 2,800 (nominal) RPM motor will give a suitable belt speed.
3,000 surface feet per minute seems to be generally accepted as a maximum safe speed for a belt.
Personally I prefer things a bit slower, especially if it’s a horizontal belt. A friend swopped a 2,800 rpm motor for a broken 1,440 rpm motor on his and it was a bit scary. If not held really tight things would get launched across the shop. Also difficult to get flat results so the right speed motor was quickly found.
Generally permanent capacitor motors have less starting torque than capacitor start or capacitor start and run ones. Permanent capacitor motors tend to have a smaller load range too. They work best, and most efficiently, on fixed loads like fans. Before I knew about such things I tried to used what turned out to be a motor designed specifically for fan use on a drill. It got very hot if run off load for anything other than the shortest of periods and soon burnt out. A general purpose permanent capacitor motor wouldn’t be so sensitive but the useful load range is always less.
Capacitor start, capacitor run motors give both best starting torque and running load variation capability so its generally worth paying extra to be sure it will work fine.
