On
19 April 2025 at 17:00 nevillet Said:
On the voltages generated:
fast hand speed = 3.5V
Attached to a battery drill at max = 57V
So when in manual mode best to disconnect the motor from the driver.
Would one wire off each winding be sufficiant?
Disconnecting motors and electronics is bad practice, don’t! Motor windings being inductive store energy, and when disconnected the magnetic field collapses causing a voltage. If there’s no discharge path, volts rise until the insulation fails somewhere. You don’t want the failure to be in the motor windings or inside the electronics. If it can go wrong, it will! All to easy for humans to throw the disconnect switch at the wrong moment.
In normal operation a stepper controller is powered by up to 40V, maybe more. It won’t be inconvenienced by a 3.5V back voltage, and the output stage will probably be robust well beyond 40V. Like as not the Electronics Engineer who designed the controller has protected it. And it’s decades since transistors were so delicate as to be called ‘three legged fuses’.
Is it likely the mill’s lead-screw will ever be spun fast enough to generate 57V? If it ain’t bust don’t fix it…
