I'm at the stage of making a motor controller for my 3 1/2" gauge shunter. I'm aware that many small electric models like this simply use a multi-step ressistor ladder. I have the opportunity to be a bit more creative as I'm doing it electronically (with only a 7Ah battery I don't want to waste any watts!) The actual controller is made, but I need to design the handheld 'control box'.
But with no driving experience what sort of controls do I need? I've got two SPDT relays to give reversing and back-emf braking, a 'horn' and I imagine a 'failsafe' that stops everything if handhel controller and engine part company will be essential.
But how should I control the speed. Will an 'up and down' button be the best way, or should it be possible to rapidly go to any setting with a rotary control? If I use +/- buttons, should they respond quickly or take a whiles to ramp up and down?
I can have up to 255 steps from off to full on, but I get the idea that most people only use a few – and fewer steps means faster reaction to the controls.
I won't be in the position of being able to nip back and forth between track and workshop, so a solution that should work reasonable first time is what I'm hoping far!
So , lots of ideas but NO practical experience – all suggestions welcomed.
