Motor brushes for a Unimat Millennium lathe
Home Forums Beginners questions Motor brushes for a Unimat Millennium lathe
  • #4881
    Ian Major
      @ianmajor42428
      Ian Major
        @ianmajor42428
        Can anyone suggest where I can get replacement motor brushes for a EMCO Unimat 3 Millenium lathe? I have tried various sources including the supplier and have drawn a blank.
        The Millenium lathe does not use the standard EMCO drive unit. The motor is contained in a box below the lathe bed, The brushes are 3.5 x 9.8mm cross section and are much smaller than the brushes in the motor on my EMCO milling machine, There are no markings on the motor to give a clue.
         Any advice would be gratefully teceived. I am crawling up the wall due to my lathe being hors de combat.
        #46085
        Gordon W
          @gordonw
          Only advice I can give is, if you can’t get the real ones,take the old brushs to a elect. factor, or auto elect. place, and get the nearest bigger size for a motor then file to size.NB motor brush.
          #46134
          Ian Major
            @ianmajor42428
            Gordon, Thanks for the reply. I will try this out in about a week’s time and let you know the results. My fear is that in fileing the brushes down I may end up looking like someone who has just emerged from a shift at the coalface!
            #46135
              Have a word with Pro Machine tools thay have got parts for my 25yr old Emco Ecomat in the past
              They have a flashing add at the right of teh page emco/wabeco/golmatic
              Jason
