I like Les's and Neils geared units on page one.
A while ago I butchered a perfectly good Machine Mart 1/2" capacity air drill to get the reduction unit out of to convert my air tapper to electric.
Reason was, to use it I have to run a big compressor for probably only a few holes so it tended to not get used. Now it's on electric it ready for just one or two holes, also the air one struggled a bit on M12 holes but the electric one can do M14 which is as big as my collets go.
But, and seeing these pictures and thinking about it I have some of these.
Desutter self feeding air drills which to be honest are not worth much second hand.
Plated bit is the gearbox and the black tube behind is the air motor and it sups some and more. Inside the control casting is the air cylinder that pushes the chuck and drive shaft out.
So chop it off behind the gearbox and fit one of these spurious 300w / 350w 450w 500w Chinese C2 / C3 mill motors and control board and you have a very nice unit ?
