Hi all,
Earlier this year I got myself a Myford Super 7, Warco A1S mill, and a good selection of tooling and material from a workshop clearance. The mill is in fairly good condition and I got it up and running with the VFD without too much trouble. The lathe was not fitted with a motor, but a few motors were included in the lot, one of which I managed to fit and get running. It's not quite as pretty and has a little wear, but certainly fine for my use. I need to improve the motor mount as it slips a little.
I finished my first starter project of a machinists hammer. Quite happy with the result, a lot of learning along the way.
I've been able to work out what most of the tools and accessories are, but I was hoping someone might be able to help me identify some of the below parts:
1)
The top part is a myford spindle/chuck mounting plate. These bottom parts look like some type of chuck plate, but the 3/6 bolt pattern doesn't align with the myford mounting plate. The centre hole does not go all the way through. The body appears to be stainless (not very magnetic at least, and very heavy), and I believe the black part may be carbon as it turns to dust when scratched with a knife, and is electrically conductive. I have one more which is threaded in the centre to fit the myford spindle. Quite odd. The larger part is stamped with either an "AK" in a circle cocked sideways, or possibly a logo with the side-profile of an eye. Two "3"'s which have been crossed through, "1.4571", and "43792". The smaller part is stamped "CG" in an oval and "93493" or "93483".
2)
This appears to be a 2 axis positioning plate. The brass knurled nut jacks the centre part up on a thread. The centre part can also freely rotate within the 3x radial slots, constrained between the two adjustable stops on the left. Seems like it wouldn't have the strength/rigidity to stand up to milling/turning operations, so maybe it's unrelated. The previous owner was in to making parts for fishing and to test fishing line.
3)
I've only put these cast parts together based on their matching colour. The T slot on the right angle fixture does not seem to fit the bed of either the Myford Super 7 or Warco. No markings.
4)
I suspect these parts are Myford, as the paint matches some other accessories perfectly. The numbering convention of the top part is also similar to another myford casting, but I can't find anything online relating to these numbers. 72/1939/1 and DBL 227/1 or 226/1
Interested to hear if anyone recognises anything!
Thanks,
Chris
