I am now up to the stage where I have centred and rough turned my cranks main bearings (Stuart No 4) and I am making a couple of blocks to enable the big end to be rough turned (well, hopfully not too rough!)
I have ‘in stock’ a small air motor which I propose to mount on the saddle, mounted with a grinding wheel to enable me to finish size the crank journals.
The motor runs off 80 psi is ball raced and quite powerfull. I need to make an arbor to fit a slim grinding wheel which will have to be able to rotate at 5500 rpm. This would be trued up with a diamond dresser prior to use.
What sort of grade wheel would I need to look out for, or would I need? one for roughing then a finishing wheel?
Apart fom the need to have the compressor running and the noise of the motor I think it ‘should’ work ok!
