My workshop “shed” is a 16′ x 12′ and purpose made to my specification.
There is no window in it at all, I decided to trade the natural light for increased security.
The door is a double one to allow access for machine tools, but one door is wider than the other, the wide one is only opened for large items and the smaller one is the normal entry door.
The floor is double thickness 3/4″ marine ply so 1.5″ thick, and is set on joists spaced 10″ apart as opposed to the normal 24″ found on cheap sheds. The whole shed is sitting on a 6″ thick reinforced concrete base.
I thought the stiffer floor might be adequate for sitting my machine tools on, but I was very wrong, even the relatively small Myford was swaying around because of the spring in the wood floor. My solution was to bore 3″ diameter holes through the ply floor taking care to miss the joists below, and to fit some slugs of steel bar down onto the concrete base, the top of each slug was slightly counterbored to form a seating for the machine leveling screws and they were sealed into the floor with silicone sealant to prevent draughts or movement.
So now all my machines are sat rigidly on the concrete and do not move at all, but with the advantage of a warmer wood floor.
The walls have been internally clad with 1/2″ ply wood but not before all the space behind was filled with 2″ thick polystyrene insulation sheet, the same sheet was used to fill the gaps between the 5″ x 3″ roof joists.
I have a very strong bench across the full 12′ width at the back which is topped with a reject kitchen worktop.
All the walls were painted white and the floor with grey floor paint prior to anything going into the shed, then a ring main was installed with 10 strategically placed double sockets for the various tools. and plenty of strip lighting for the bench and machine tool general lighting.
I run a de-humidifier set at 40% humidity, and one oil filled 1.5Kw radiator which comes on via a frost stat set at 7°C. This heater does not actually come on very often, but it has cured all my rust problems that I used to have when my workshop was in a prefab concrete garage, and the temperature remains very stable inside even if it changes quickly outside.
I had this shed built, delivered and erected for £1100 in Jan 2008
Phil
Edited By Phil P on 07/01/2012 14:57:46
