modifying Schaublin collets
Home Forums General Questions modifying Schaublin collets
Viewing 2 posts - 26 through 27 (of 27 total)
  • #766604
    vic newey
      @vicnewey60017
      Thanks for the replies, I did actually manage to do it with a 3mm end mill, I had thought the metal would be too hard for the cutter to get a grip on but it worked very well as I took it really slow moving the cutter horizontally in the slot. It’s not exactly a superb example of milling but it did the job and the collet fits!
      I did not get an email showing I had replies to my post for some reason
      old mart
        @oldmart
        I have often milled case hardened steel using solid carbide endmills. You do need fine control though because of the brittle nature of carbide, no freehand use.
