modifying Schaublin collets
Home Forums General Questions modifying Schaublin collets
  • #163020
    Ken Weeks
      @kenweeks58536
      I have a Pultra 1590 lathe that I am getting back into use, it is designed to use 20mm collets.
      The likelihood of finding genuine collets is very unlikely.
      Schaublin w20 collets have the same thread and dimensions but the locating key way slot is about 3mm to short.
      Would it be possible to extend the slot?
      Ken
      Ken Weeks
        @kenweeks58536
        #163027
        Matt Harrington
          @mattharrington87221
          You will probably have to grind the keyway as they are hardnened. A pencil air grinder with a suitable wheel is chaeap and effective for this.
          Matt
          #163047
          Ady1
            @ady1
            Find a duplicate collet and practice on it to see what works best.
            Collets can be extremely hard and they are also flexible which makes working on them quite difficult
            As mentioned, grinding is probbly the way to go
            #163048
            jason udall
              @jasonudall57142
              Just a thought…wouldn’t modifying the key be better…only one to do rather than a set…
              Of course this might be one very difficult mod versus 10-20 simple mod s…
              And of course the is the possible effect on the “value” of the lathe…
              #163056
              Ady1
                @ady1
                Just a thought…wouldn't modifying the key be better…only one to do rather than a set…
                It's in pretty deep but could be coaxed out and ground down…
                Ken. Are you sure that these collets have the same profile?
                The angle at the thick end for example?
                #163077
                Ken Weeks
                  @kenweeks58536
                  Thanks for the replies.
                  Removing the key entails stripping down the headstock, not to sure I want to do that again.
                  I think if possible my chosen option of modifying the collets is the safest way to go.
                  Ady I take your point about the draw angle, the idea was to modify one and test.
                  I have the feeling that I read somewhere about modifying collets with a carbide cutter.
                  Ken
                  #163084
                  John Haine
                    @johnhaine32865
                    At one point I inherited an Aciera F1 and found that this company:
                    http://www.floydautomatic.co.uk/products.asp
                    actually make collets, in fact they make Schaublin ones, so maybe they could make some with a longer keyway? They are based in Baldock, Herts. I seem to remember that their W20 ones seemed quite reasonably priced, so may not be prohibitive to get specials especially since it's a small variation. Could even be a niche product for them as there are enough Pultras around, I bet they have been asked before.
                    John.
                    #163088
                    Ady1
                      @ady1
                      The collets I wondered would fit are those Alexander/Deckel FP1 collets but I never bought one to try it out
                      #163089
                      Ady1
                        @ady1
                        dubble post
                        Edited By Ady1 on 08/09/2014 21:40:19
                        #163090
                        Emma Watley
                          @emmawatley24025
                          hi im new and just started an engineering course in college, just on here to look for help and advice, emma x
                          #163124
                          Ken Weeks
                            @kenweeks58536
                            The 1590 is a rare lathe I have only seen one other for sale in the last year.
                            It is about three times the size of the 17xx series, I have posted a few pictures in Kens album.
                            Thanks for the link to http://www.floydautomatic.co.uk/products.asp, I have found a supplier in Germany as well.
                            The Alexander/Deckel FP1 collets appear to have a different thread.
                            Hi Emma good luck with your Engineering course the start of a great career.
                            There is a beginners questions section on this forum, have a read through post in this and other sections to give you an idea of what the forum is all about.
                            Harold Hall http://www.homews.co.uk/ has an interesting site, and I have found Home Model Engine Machinist http://www.homemodelenginemachinist.com/ interesting.
                            A general internet search for model engineering should bring up a selection to look at and find something of particular interest to you.
                            Ken
                            #163133
                            Ian S C
                              @iansc
                              Emma, another web site worth looking in on is Model Engine Maker. Good luck with your engineering course, and career in engineering. Ian S C
                              #163502
                              Bob Stevenson
                                @bobstevenson13909
                                I think you will find that collets for the Smart & Brown lathes,…the models L and A, will also fit the 'big' Pultra as both are 20mm and made by the same company(Pultra now defunct)
                                #163549
                                Ken Weeks
                                  @kenweeks58536
                                  Hi Bob
                                  Had a look into this Lathes.co.uk website and the Yahoo Smart and Brown group give the spindle bore as 63/64" or 25mm unfortunately..
                                  Thanks for posting and giving me your thoughts.
                                  Ken
                                  #163550
                                  Oompa Lumpa
                                    @oompalumpa34302
                                    Posted by Emma Watley on 08/09/2014 21:42:27:
                                    You are the daughter of Godzilla and I claim my five pounds!
                                    graham.
                                    #163554
                                    Emma Watley
                                      @emmawatley24025
                                      Graham I think your nuts lol what do you mean daughter of Godzilla?? x
                                      #163739
                                      Muzzer
                                        @muzzer
                                        I don't know if you were thinking of my recent use of a carbide indexable tool for cutting a hardened steel ballscrew housing but some of the common grades are indeed rated for working hardened steel. You have to run the piece at the specified surface speed and take proper (but light) cuts but if you don't mind setting fire to yourself and your workshop, it may be worth trying. The limitation may be getting your machine to deliver enough power at a high enough speed for the tool to cut properly. The advantage is that you don't need to anneal the work or use a grinder and it's reasonably quick.
                                        My experience was with the flange of a hardened ballscrew of around 2" diameter that needed to be turned down to about 1.2" on the Bantam which has something like a 1.5HP motor. I think I was using in the region of 1800-2000 rpm (ie slightly overspeed) and power feed with carriage stop. The final result was clean and accurate and cost me almost 2 inserts (3 edges out of 4). The sparks were mighty.
                                        My main concern would be the workholding, given the spring of the collet jaws. I have no idea if that is a problem.
                                        There are a couple of photos of the process in one of my albums near the bottom.
                                        Murray
                                        #163763
                                        Ken Weeks
                                          @kenweeks58536
                                          Hi Murray
                                          Thanks for the post.
                                          Still thinking about how to do this having taken all comments on board.
                                          The key way slot needs to be extended by 4mm x 1mm deep.
                                          Ken
                                          #163765
                                          Matt Harrington
                                            Have a look here:
                                            I bought one from a famous auction site for £15 and have found it useful for the sort of job you want to do on hardened steel.
                                            Matt
                                            #163780
                                            Ken Weeks
                                              @kenweeks58536
                                              Hi Matt
                                              You are the second person to suggest a pencil air grinder, the link to the video was great as I could see what you were talking about.
                                              A picture is worth more than a thousand words to me, and yes very cheap on the well known site.
                                              This seems to be the way to go, just have to work out how to hold it all.
                                              Ken
                                              #765772
                                              vic newey
                                                @vicnewey60017
                                                I just resurrected this thread to see if anyone did manage to lengthen the keyway slot on a collet.
                                                I have the same problem as the OP, my collet is a 15mm shank Boley, one of a number of Crawford & Boley collets that came with my lathe and the one I want to use won’t draw in as it’s keyway slot is 5mm shorter than the others for some unknown reason.
                                                I guess grinding is the only option here, the original OP doesn’t seem to have visited the forum lately so might not hear from him.
                                                #765819
                                                  Vic
                                                  I regret that I remain in no position to do any ‘workshop’ activities … but I would like to add a comment if I may.
                                                  A common way of producing these slots was with a horizontal milling cutter [as evidenced by the run-out slope], and it would seem very appropriate to do the extension by the same method.
                                                  Note: I have no idea what the price of a suitable Tungsten Carbide cutter might be.
                                                  bernard towers
                                                    @bernardtowers37738
                                                    Yes or the more common T slot / woodruff cutter in carbide. you dont mention the width but the typical 4mm wide cutters are about £4 on your favourite site
                                                    #765826
                                                    Roderick Jenkins
                                                      @roderickjenkins93242
                                                      Tubal Cain in “Simple Workshop Devices” describes a fixture for modifying a selection of collets from various manufacturers to a standard key way size.  Hardness of the collets is described as being variable from manufacturer to manufacturer with very few being “dead hard”.  He used a Woodruffe cutter, presumably in High Speed Steel in his day, slowly and with plenty of cutting oil.
                                                      Rod
