Model machine name plates
Home Forums Help and Assistance! (Offered or Wanted) Model machine name plates
  • #211649
    Tractor man
      @tractorman
      Hi all,
      I am just staring out on building a quarter scale model of a Kerry speedc 8 pillar drill. I want to put realistic name plates on it so need to know how to source etched or engraved manufacturers name badges etc.
      I have seen Barry Jordan's work and would love to know how he produced such detailed plates for his Bridgeport etc. If you're reading this Barry drop me a line!
      I will post photos as I progress. Regards Mick
      Tractor man
        @tractorman
        #211653
          Mick,
          That sounds a great project, and at quarter scale, the finished item should be a useful little machine. [assuming it's not just for show]
          I look forward to following your progress.
          P.S. … Just spotted your Linisher photo star
          Edited By Michael Gilligan on 11/11/2015 23:40:42
          #211666
            Neil did a write up on etching plates a while back in ME
            The other options for things like the plates found on things like motor plates is to use self printed transfers for the darker areas. This is a screen printed one but transfers would work.
            And a nameplate done with transfer paper on a home printer, thats 15mm dia
            For simple raised letters you can get individuals from some of the model railroad suppliers, I did these with "Slaters" letters
            Edited By JasonB on 12/11/2015 07:32:22
            #212051
            Tractor man
              @tractorman
              Thanks for the posts. I have made waterslide transfers before but want to replicate the nameplates as realistically as possible.
              I have a couple of companies who seem to be able to do this so I will keep you updated as to how things go.
              The base of the drtill is complete as I decided to work from the ground up so that I had somewhere to put the drilling head when it was finished. Plus that's the most complex bit so I have time to learn about gear cutting etc.
              Regards mick
              #212065
              Russell Eberhardt
                @russelleberhardt48058
                It's quite easy to make them yourself. I've used Mungolux photoresist film laminated onto brass sheet with SWMBO's domestic iron. A computer generated artwork printed with an inkjet printer on transparent film is then used to expose the UV sensitive film. I use a 3 second exposure to sunlight (cheaper than a light box) and develop in washing soda solution. Etching with ferric chloride at room temperature removes about 1 thou per hour. You can then fill the etched parts with paint.
                Russell
