model aero engine cams
Home Forums Workshop Techniques model aero engine cams
  • #125285
    david williams 5
      @davidwilliams5
      I want to build the Chenery V twin model aero engine but having a problem sorting out the timing cams which I want to make first before doing anything else.Can anyone help me with advice, guidance,or sources of detailed instruction.I live in the Warrington, North West England area & able to travel areasonable distance. David Williams.davfou@aol.com 01925754418
      david williams 5
        @davidwilliams5
        setting up for &machining
        #125286
          Can you scan a bit of the drawing that shows the cam and post here then more people will be able to offer advice as there are several methods but not all may suit your cams
          There are a few methods shown on Modelenginenews
          Had a quick look at Hemmingways site and looks like you could use the boring head method, take a look at this photo in my album and the following three, its a similar cam for a Hoglet V-twin
          J
          Edited By JasonB on 23/07/2013 10:21:27
          #125293
          neville rigg 2
            @nevillerigg2
            Hi Dave, build instructions were serialised in Engineering in Minuture some time in the seventies, I have one that I started but never completed, can give you the dates if you require them good luck with the build, cheers nev.
            ps,used to live in Rochdale but now Atlanta so a visit might be expensive.
