Following on from the welding in the workshop article in MEW, I have a MMA set but now need to weld some thin material which one would usually use I suppose MIG. However, I would rather not splash out on a MIG set at the moment if I can afford it.
There is an item known as a ‘Body Welding Attachment’ for a MMA set which is advertised as being able to weld using MMA down to 22g(?), using a pulsating action with 1.6mm rods.
Anyone have any experience using such an attachment? Is it worth buying?
Out of interest, my MMA set, which I have had for many years, used to suffer from overheating when using large rods for extended periods, giving rises to enforced cooling off periods of about an hour. I fitted a fan out of an old computer to give a forced air flow over the set and since then, no more overheating!
Chris
Edited By ChrisH on 27/05/2009 10:33:41
