Hi guys,
I sent yesterday replacing the headstock drive belt on my ML7.
On refitting the the bearing caps, I found the spindle would not turn – even with all the belt tension released.
I stripped down all of the bearing caps again and removed the belt. When lowering the spindle back into the bearings. I noticed that as it started to enter the rear bearing, the flange at the back end of the spindle was binding against the bearing housing.
Nothing has been touched during the changing of the belt, the only screws that were undone were the 4 in the bearing caps. I even made sure that the laminated shims stayed in the same place – even the same way round!
Can anyone offer me any guidance to set the head correctly as I am getting frustrated now!
Cheers
Tony
