I have been testing the printed ML7 spindle lock, kindly supplied to me from a forum member, and so far it has been amazingly good. It removes any chuck or face plate from my ML7 with ease. I also have an ML10 (same bull wheel) which is a swine when it comes to chuck removal (Can't figure out why). It needed a large lever in the chuck jaws (at right angles to the lathe axis), the printed spindle lock coped with ease.
I then did the unthinkable, put a chuck on the mandrel nose using only 2 or 3 turns and then turning on the motor. Those of you that may have done this, will know that it is virtually impossible to get the chuck off again. An even larger leaver (about 3 feet long!) and the printed lock. One good heave, loosened the chuck with no problems.
I shall continue to abuse the printed lock and see if I can destroy it overtime. Somehow I don't think I will manage to do so.
Andrew.
