ML7
ML7
  • #272706
    Peter Walsh 4
      @peterwalsh4
      New member here, just traded up from a Drummond ML4 to a Myford ML7.
      Few jobs little jobs to get it up to spec, fitted a 3 phase motor with variable speed control, eBay bargains and Chinese switch gear.
      Shahe DRO with Adruino interface with TouchDRO in progress.
      Back plate for 4 jaw chuck needs a tap run down it so if anyone has a 1 1/8 12 TPI tap they would sell/loan please get in touch
      Peter
      Peter Walsh 4
        @peterwalsh4
        #272866
        Chris Evans 6
          @chrisevans6
          Welcome along Peter, lots of good advise on this forum. I cant help with a tap but if you put up your location someone may be close to you.
          #272874
          ianj
            @ians
            Peter.
            I have a set of taps you could borrow. Where are you? I'm in Stoke On Trent..
            Ian
            #272947
            Georgineer
              @georgineer
              If you want to buy them, Tracy Tools have them hidden away in their catalogue but not identified as Myford compatible. Look under 'Whitform' and scroll through till you reach the right one.. Here's a link:
              http://www.tracytools.com/taps-and-dies/whitform-taps-dies?product_id=1161
              George
              #272950
              Peter Walsh 4
                @peterwalsh4
                Hi Ian J,
                Thanks for the offer, I am in High Wycombe area, I'm not in a rush so if I can't find one locally I'll give you a shout as I may be up that way in February
                Hi George,
                Thanks for the info, I'll take a look there.
                Peter
                #272951
                Trevor Drabble 1
                  @trevordrabble1
                  Peter, I believe RDG sell them , and I assume they will be at the Alexandra Palace model engineering show in January.
                  Trevor.
                  #272961
                  Peter Walsh 4
                    @peterwalsh4
                    Hi Trevor,
                    Chronos list them too ( £ 16 cheapest) but none in stock.
                    It may be cheaper to wait for an old back plate to come up on Ebay and fit it to that.
                    Regards Peter
