Mk1 Myford Super 7 lathe
Home Forums General Questions Mk1 Myford Super 7 lathe
  • #29154
    paul sheldon
      @paulsheldon74099
      Oil drip feed
      paul sheldon
        @paulsheldon74099
        Help
        I have bought a Mk1 Myford Super 7 lathe and doing a full restoration on it however there is an oil reservoir built into the Headstock. Underneath is a plastic see through lens and a white plastic cup both are broken and needing replacement however there is a brass tube running through connecting both the oil Reservoir and plastic cup which will need to be removed its rock solid so I imagine will need to be drilled out and replaced from the early research that I am doing it would seem a tad difficult to obtain as in no chance
        Can someone help me please any help and advice would be much appreciated
        Thank you for reading
        Paul
        #642630
        not done it yet
          @notdoneityet
          Drilling it out, if necessary is obviously a job while the spindle is separated (or at least the top bearing housing removed) from the headstock.
          However, you have a lathe, so that part can easily be made, in the lathe, after the restoration is mostly complete, if necessary?
