Mixed Metals
Mixed Metals
Home Forums Beginners questions Mixed Metals
  • #502568
    Simon Neath 2
      @simonneath2
      HI
      I am building the Clayton Wagon and have come to the crossheads.
      I only have one gun metal casting, don't ask I don't know what happened to the other one. Would it be a problem if I made the other one from brass or should they both be the same material and if so why apart from looks?
      Thanks in advance
      Simon Neath 2
        @simonneath2
        #502585
        Chris Gunn
          @chrisgunn36534
          Simon, crossheads are made from gun metal so they wear well, brass will not wear anywhere near as well, could you get a lump of bronze or gunmetal and use that?
          Chris Gunn
          #502590
          Simon Neath 2
            @simonneath2
            Hi Chris
            Thanks for the advice I have a lump of bronze I can use
            Simon
            #502592
            Paul Lousick
              @paullousick59116
              Gunmetal is a variety of bronze and formerly used for making ordnance (guns).
              Modern admiralty gunmetal is composed of 88 percent copper, 10 percent tin, and 2 percen zinc and is used for gears and bearings that are to be subjected to heavy loads and low speeds. It withstands atmospheric, steam, and seawater corrosion and is suitable for valves, pump parts, and steam fittings.
