Mitsubishi vfd
Mitsubishi vfd
Home Forums Electronics in the Workshop Mitsubishi vfd
  • #401368
    David Siddle 1
      @davidsiddle1
      I'm needing a little help picking the correct drive. I've looked at the manual on line, but I'm still a bit confused Could anyone please tell me if the following model would be suitable for powering my 3ph fobco from domestic supply? Many thanks.
      FR-D720S-042SC-EC
      David
      David Siddle 1
        @davidsiddle1
        #401371
        Wingo
          @wingo
          Hi,
          This is a 230v input single phase and 220v three phase ouput inverter. Rated at 0.75kw.
          Your motor will need to support 220 / or 230v phree phase supply, often by connecting in Delta on a dual rated motor.
          It will 'putting in a box' to protect it with room to be able to loose the heat generated.
          Then with correct configuration it will then work!
          If you not sure about the motor put up a photo of the motor rating plate.
          Michael
          #401377
          Brian Hutchings
            @brianhutchings
            Hello David, You could try giving Direct Drives a call, I found them to be very helpful recently.
            Direct drives
