MIT Videos engineering training videos
Home Forums Hints And Tips for model engineers MIT Videos engineering training videos
  • #70180
    David Clark 13
      @davidclark13
      MIT Video
      Machine Shop 1
      Machining Skills for Prototype Development:
      1) Basic
      2) Layout Techniques
      3) Basic Tools: Drill Press, Band Saw, Belt Sander & Grinder
      4) Locating and Drilling Holes
      5) Tapping Holes
      duration 40:32
      Edited By David Clark 1 on 12/06/2011 15:55:50
      David Clark 13
        @davidclark13
        #70181
        David Clark 13
          @davidclark13
          MIT Video
          Machine Shop 2
          1) Basic 2
          2) Drilling Holes
          3) Special Drills for Plastics and Hard or Abrasive Materials
          4) Drill Press Limitations
          5) Bandsaw
          6) Suitable Speeds, Feeds and Materials
          7) Bandsaw Setup
          8) Using the Drill Press Vise
          Duration 57:33
          Edited By David Clark 1 on 12/06/2011 15:55:15
          #70182
          David Clark 13
            @davidclark13
            MIT Video
            Machine Shop 3
            1) Basic 3
            2) Good Practice – Clean Up
            3) Small Belt Sander Configurations
            4) Grinder Operations and Materials
            5) Deburring and Buffing
            6) Finishing Techniques
            Duration 30:02
            Edited By David Clark 1 on 12/06/2011 15:53:43
            #70183
            David Clark 13
              @davidclark13
              MIT Video
              Machine Shop 4
              Milling Machine 1
              Layout and use; what the different parts do.
              Quill feed allows you to move tool up and down.
              Axis hand feed feed/crank on axis with dials to adjust the Bed.
              Gib locks holds/locks bed to saddle and saddle to knee and knee to body of machine
              Locking ring adjustments.
              Power feed attached to one or more of the axes.
              Forward/reverse knob and variable speed control.
              Digital readouts.
              Measure position of axes to 0.001inch or in mm.
              Milling machine setups.
              Squaring the head.
              Square=Z-axis of head so Quill is perpendicular to axis of bed.
              Squaring the vise.
              Adjusting the vice so the back (stationary) jaw of vice is parallel to the bed.
              Machine safety, protocol and shop safety.
              Milling machine accessories.
              Workholding techniques.
              Milling machine tools.
              Drill chuck drilling and reaming.
              Boring head more precise cutting to 0.0002 inch.
              Flycutter used to square up a part [4 teeth and 1 single tooth].
              End Mill shank type milling cutter.
              Collet Chuck holds End Mills.
              Saws used to make deep narrow slots installed on an arbor.
              Reamers used to smooth out inside of drilled holes.
              Edge finder and center finder used to locate centre punches or holes on a milled part.
              Boring tool used on a shank to bore holes.
              Duration 50:33
              Edited By David Clark 1 on 12/06/2011 17:02:59
              #70184
              David Clark 13
                @davidclark13
                MIT Video
                Machine Shop 5
                1 Milling Machine
                2 Square and Hex Collett Blocks-used to hold/clamp parts to machine features on 4 and 6 sides of a part, respectively 2 V Blocks Holding parts to machine features into parts and end of parts
                3 Hold-down Clamps Used to hold large or irregularly shaped parts
                4 Using Angle Blocks Used to hold materials to machine features not perpendicular on a part
                5 Drill Press Vice Used to hold a part to machine a feature @ 45? angle and other positions/angles Also used with angle blocks to hold parts
                6 Lathe Chuck With Vise Used to hold parts in the milling machine; not accurate method, but quick/convenient
                7 Double Sided Tape Used to hold a part in a vice securely without distortion
                8 Squaring High Aspect Ratio Parts Used to hold a part to be machined securely and squared
                9 Right Angle Attachment A right angle gear box to mill features in an end of a larger/slender part that is clamped in the vice.
                10 Slitting Saw A saw blade that is used to cut slots/slits/features in a part Can also be used with a right angle attachment
                11 Rotary Table A bench/table attached to the bed of the machine used to machine circular parts, grooves, circles, segments Dial indicator and Co-Axe indicator uses to square/center the Table to the Y axes
                12 5 C Collett Indexer Used to hold Colletts and position parts in up to 24 positions for various milling features
                Duration 1:03:33
                Edited By David Clark 1 on 12/06/2011 16:23:10
                #70185
                David Clark 13
                  @davidclark13
                  MIT Video
                  Machine Shop 6
                  Milling Machine 3
                  1 Squaring a part, maching all surfaces so they are flat and perpendicular to one another and nominally to the part that will be milled; removing burrs
                  2 Squaring a Plate Squaring the sides of a part/plate to the dimensions of the finished milled part; remove burrs
                  3 Using the Edgefinder Used to locate the edge of a part relative to the spindle of the machine
                  4 Drilling Holes Drill press used to drill holes in parts; center drill milling and other drill bits; setting depth stop
                  Duration 46:33
                  Edited By David Clark 1 on 12/06/2011 17:07:45
                  #70186
                  David Clark 13
                    @davidclark13
                    MIT Video
                    Machine Shop 7
                    1) Basic
                    5) Tapping Holes
                    duration 40:32
                    Edited By David Clark 1 on 12/06/2011 17:09:33
                    #70187
                    David Clark 13
                      @davidclark13
                      MIT Video
                      Machine Shop 8
                      Machine Shop 8 Lathe 1
                      1 The Lathe Components @ Set-Up Axes and Feeds
                      2 Turning Tools
                      3 Turning and Facing
                      4 Cutting Off a Part
                      Duration 45:02
                      Edited By David Clark 1 on 12/06/2011 17:12:10
                      #70188
                      David Clark 13
                        @davidclark13
                        MIT video
                        Machine Shop 9
                        Lathe 2
                        1 Tapping
                        2 Boring
                        3 Knurling
                        4 Cutting Tapers with the Compound
                        5 Turning Shafts Use of live center
                        6 Single Point Thread Turning
                        Duration 47:33
                        Edited By David Clark 1 on 12/06/2011 17:14:04
                        #70189
                        David Clark 13
                          @davidclark13
                          MIT Video
                          Machine Shop 10
                          Machine Shop 10 Lathe 3
                          1 Lathe Chuck
                          2 Lathe Arbors
                          3 Turning Between Centers
                          4 Face Plate Irregular Shapes
                          5 Face Plate Thin Materials
                          Duration 34:32
                          Edited By David Clark 1 on 12/06/2011 17:16:01
                          #70190
                          John Stevenson 1
                            @johnstevenson1
                            Are these supposed to be links to the video’s ?
                            If so they are not working
                            #70192
                            David Clark 13
                              @davidclark13
                              Hi John
                              They are working for me.
                              Can you try again?
                              regards David
                              #70193
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi David, they have worked for me, just a bit slow getting started, long pause between clicking on the play button and anything happening.
                                Unless you haven’t imported them yet, there is nothing in the spaces 6 to 10.
                                Regards Nick.
                                Edited By Nicholas Farr on 12/06/2011 17:06:56
                                #70194
                                Terryd
                                  @terryd72465
                                  Hi John,
                                  These have been discussed previously in another thread and the links are all there. Sorry I can’t remember the title of the thread,
                                  T
                                  Edited By Terryd on 12/06/2011 16:41:26
                                  #70195
                                  John Stevenson 1
                                    @johnstevenson1
                                    I can see the links in the other thread but not in this one.
                                    XP using latest Firefox.
                                    This is the link to the first one I am placing, can this be seen ?
                                    John S.
                                    Edited By John Stevenson on 12/06/2011 16:51:24
                                    #70196
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi John. no, have tried it twice, the play button comes up then dissappers, tried the pause and play, message says “sorry clip not found”.
                                      Regards Nick.
                                      #70197
                                      John Stevenson 1
                                        @johnstevenson1
                                        No what I meant was could the link be seen.
                                        For me on my post the MIT Video 1 is highlighted in purple and is clickable.
                                        On David’s posts the video 9 [ or whatever] is not highlighted and is not clickable.
                                        What are others seeing. ?
                                        #70199
                                        David Clark 13
                                          @davidclark13
                                          Hi There
                                          All videos are working for me.
                                          Internet Explorer 8
                                          regards David
                                          #70201
                                          Nicholas Farr
                                            @nicholasfarr14254
                                            Hi John, sorry I missunderstood what you meant. On all of David’s, I see a black video screen, with a semi-transparent grey play button in the middle, some of them have; “An MIT Video production” showing through the button.
                                            Regards Nick.
                                            I have IE9, BTW.
                                            Edited By Nicholas Farr on 12/06/2011 17:31:40
                                            #70202
                                            Jim Cozens
                                              @jimcozens
                                              John,
                                              when I click on it. David’s link just disappears when I click on it.
                                              Jim
                                              #70203
                                                John your purple text works for me and is the same way I posted the link in davids other thread.
                                                David’s also work but as they come up on the ME forum page they are slower to load and smaller (though full screen works) David it would be better to edit all your posts to John and my type of link.
                                                Using IE9 on XP
                                                Jason
                                                Edited By JasonB on 12/06/2011 17:49:05
                                                #70204
                                                John Stevenson 1
                                                  @johnstevenson1
                                                  Well I can’t link to David’s so it looks like a Firefox issue ?
                                                  #70205
                                                  David Clark 13
                                                    @davidclark13
                                                    Hi There
                                                    Click on the full screen link.
                                                    They then become bigger.
                                                    John is welcome to post his links.
                                                    Mine are fine for me.
                                                    regards David
                                                    #70206
                                                      I seem to remember other people having a job viewing them when they have been posted on other forums in the past so its something common to MIT and not just you.
                                                      J
