Just had a few minutes to spare and played with the gear count and tooth size.
If you were to use a combination of 1.5MOD and 2MOD both of which can be bought off the shelf quite cheaply from the likes of Beltingonline then with slight alteration to the thickness and bore sizes for could get all the gears for about £130 which is less than the ME suppliers sell a set for the 1" engine for.
Crankshaft 19T & 25T both 1.5MOD
2nd shaft 38T & 32T meshing with the above and a 25T on the end all 1.5MOD
3rd Shaft 64T 1.5MOD and a 24T 2MOD
Final drive 77T 2MOD
Low speed is exactly the same and high only a fraction different and back axle ends up just 0.46mm higher though you could play about with 3rd shaft position a bit to get axle in same place.
Edited By JasonB on 30/07/2019 11:00:38
