Minimum recommended silver % for boiler build
Home Forums Materials Minimum recommended silver % for boiler build
  • #751510
    Blue Heeler
      @blueheeler
      Building a small vertical copper boiler, what’s peoples recommended minimum silver % for the silver solder for the  boiler build?
        Not sure what the cadmium situation is downunder. If you can use cad bearing solder then 42% which was the old Easyflow No1 percentage. If you can’t use Cad bearing then a higher silver content keeps the characteristics similar but needs to be 55%, this is the lowest melting point one.
        #751520
        Blue Heeler
          @blueheeler
          Thanks Jason, I can get 45% Silver Solder with Cadmium locally (an hour away).
        Home Forums Materials Topics
