Most small lathes have various design weaknesses.
My first lathe was a unimat, with 12mm bedbars.
Now if they had made those bedbars 16mm…
Cowells Lathes seem to be pretty good, but very expensive.
Getting it all “just right” doesn’t always happen, even with good manufacturers, because there are two opposing areas. Roughing and Finishing.
I have an old 1590 pultra which has a broken topslide t-slot section.
It’s been well repaired but looking at it more closely, the cross slide and topslide are pretty flimsy compared to the head, bed, and tailstock which are hugely strong and stiff.
So only light/moderate cuts are intended on this lathe even though the lathe is very stiff, someone tried to rough a workpiece…and broke it, which is not hard to do.
My Drummond on the other hand has the same 3-1/2 inch centre height as the pultra, and only an MT1 taper…but a hugely strong saddle and cross slide which with a chunky toolpost and a half inch tool can rough big chunks of metal away, and even cut down heat hardened stainless steel billets etc.
However, the Drummond saddle and topslide aint much use for efficiently producing very fine final cuts, it’s a real fiddle and I often polish the last critical bit, whereas the Pultra topslide appears to be useless for roughing, but good for 1-2 hundredths of a millimeter on those very fine final cuts.
I’m actually looking at fitting the pultra topslide to the drummond bed at the minit, to see if I can get the best of both worlds on one hobby lathe.
2 cents
Edited By ady on 11/12/2010 10:22:06
