Miniature pressure gauges
Home Forums Locomotives Miniature pressure gauges
Viewing 3 posts - 51 through 53 (of 53 total)
  • #278756
    Ian S C
      @iansc
      Except that that one was the origonal, built by the inventor, some one might like to work out the system of valves, and a model could be built. It is of course an etching, not a photograph, so it may not be exact.
      Ian S C
        ^^^ Slightly better detailed in the picture I linked on 16th.
        Anonymous
          Posted by paul rushmer on 18/01/2017 09:29:28:
          Is there not normally a hair spring around the needle spindle to keep the backlash all one way?
          Correct, and that is my intention. Watch hairsprings seem to readily available online. However, one might as well start by minimising backlash in the mechanism. While the spring should take it out, it will be be affected by vibration. One doesn't really want the needle bouncing around if the road is a bit rough.
        Home Forums Locomotives Topics
