Miniature metric spanners
Home Forums Workshop Tools and Tooling Miniature metric spanners
  • #599020
    Kevan Shaw
      @kevanshaw32462
      Hi, I need to get hold of spanners and or box keys for very small metric hex head bolts M1 up. Any idea who actually stocks such things?
      thanks
      Kevan
      Kevan Shaw
        @kevanshaw32462
        #599023
          This is the best I can find for now: **LINK**
          https://www.zoro.co.uk/shop/hand-tools/spanner-sets/metric-open-ended-spanner-set-3-2-8mm-set-of-6/p/ZT1005516X
          P.S. __ Box Keys / Nut Runners should be relatively easy to find.
          Edited By Michael Gilligan on 24/05/2022 00:44:15
          #599027
          Jon Lawes
            @jonlawes51698
            I know Model Engineers Laser do laser cut spanners in small sizes (BA I think), they often add to their line up based on customer requests. Assuming they can physically do it they would probably be keen to add to their possible stock list.
            #599031
              For box spanners then GHW go down to 1mm A/F hex (SW is the hex size) they also do small nut drivers which I have several of and they start at 2.5mm hex which fits their M1.6 nuts
              They have open ended spanners down to 2.5 hex but their smaller ones the link seems to be broken at the moment but like the box spanners I seem to recall they go down to 1mm hex
              Knupfer go down to 1.5mm in open ended spanners and have a similar size range in box spanners/nut drivers
              Edited By JasonB on 24/05/2022 07:10:04
              #599033
              John Haine
                @johnhaine32865
                MEL have a standard set from which you separate the individual spanners. They are generic sizes and hopefully you can find one that fits the nut in question. I'm not sure what the smallest size is, can check. I have an excellent local tool shop that stocks a wide range but I'm not sure how small, but if you're in range of West Suffolk they are bolthole.co.uk – don't sell online yet.
                #599039
                  Interesting to see that GHW sells Elora spanners yes
                  So it’s probably also worth browsing here: **LINK**
                  https://products.elora.de/en/Products/Spanners-and-Wrenches/
                    Posted by JasonB on 24/05/2022 07:05:59:
                    For box spanners then GHW go down to 1mm A/F hex (SW is the hex size) …
                    That’s impressive !
                    **LINK** : https://ghw-modellbau.de/index.php?cPath=59_318_328_330
                    HOWARDT
                      @howardt
                      I have a set of nut spinners for upto 6AF and a set of open and ring spanner’s. The spanner’s are a bit on the thick side but do work. All from that online trader.
                      #599049
                      John Haine
                        @johnhaine32865
                        I checked the set I have from MEL and the smallest is ~2.5mm a/f
                        #599050
                        Jon Lawes
                          @jonlawes51698
                          If requested I'm sure they could do smaller.
                          #599072
                          Howard Lewis
                            @howardlewis46836
                            Anything from Cromwell Tools, in UK?
                            #599078
                            Danny M2Z
                              @dannym2z
                              #599081
                              Hollowpoint
                                @hollowpoint
                                You can get Wera micro "nut spinners" in small sizes I know they go down to at least 1.5mm
