Mini/precision screwdrivers
Home Forums General Questions Mini/precision screwdrivers
Viewing 25 posts - 1 through 25 (of 32 total)
  • #700566
    Harry Wilkes
      @harrywilkes58467
      Can anyone recommend/suggest a good set of mini/precision screwdrivers ?
      H
      peak4
        @peak4
        Well over 20 years ago I bought a set branded as The International Tool Company and they have served me well.
        Their only obvious disadvantage is that the actual screwdriver ends are quite short, so I occasionally have a problem reaching small screws in deep holes.
        Recently I spotted some which look identical but a different colour labelled as;
        CK Tools T4896 Precision Multi Blade Screwdriver Set
        I bought a box off eBay, with a discount coupon, but I’m sure they are available elsewhere too;  check around, the price varies.
        image_2023-12-20_154723551
        I’ve not used them much, since they were bought as a spare set, but they seem OK, and hopefully as good as my original red ones.
        edit, it looks like RDG sell them too
        Bill
        #700589
        Robert Atkinson 2
          @robertatkinson2
          I bought one of these sets:
          http://www.amazon.co.uk/gp/product/B0921NTGDJ
          Not the cheapest but very comprehensive aand good quality. It covers a lot of the specials and “security” screws used in a lot of modern items.
          Robert.
          #700603
            That ‘Barley Sugar’ handle is rather nifty, Robert !
            Harry Wilkes
              @harrywilkes58467
              Thanks Bill & Robert will check the links out can’t look at RDG due to a dispute with Myford ebay some small minded person blocked me. There loss not mine
              H
              #700609
              Mick B1
                @mickb1
                I’ve had Halfords’ 6-piece set in blue plastic since I can’t remember when – probably 20 years or so – and they’ve served my needs quite nicely. I was quite surprised to see they’re still selling it – 6 quid – and I hope the quality’s still the same.
                On mine the steel has stood up to some fairly brutal use, including regrinding for forgotten reasons. I’ve turned the handle of the #1 Phillips bit to expose a bit more shank for a deep hole, but I’d buy the same set again if the one I have got lost or the casing broke up irretrievably.
                #700649
                Bazyle
                  @bazyle
                  Used to be the sort of thing you picked up at the ME exhibition at Shesto or Proops stand. Gone are the days…….
                  #700650
                  Harry Wilkes
                    @harrywilkes58467
                    Bayle they say ‘all good things must come to an end ‘ let keep our fingers crossed for here
                    #700655
                    Bill Phinn
                      @billphinn90025
                      Kennedy-Pro Pro-Torq Precision screwdrivers, in sets of 7 or 9, are good drivers and good value.
                      I just buy them individually.
                      The 25 piece Wera (05134000001) Kraftform Micro Big Pack covers most needs, but lacks a T9 Torx.
                      #700692
                      Russell Eberhardt
                        @russelleberhardt48058
                        It all depends on what you mean by “good”.  Bergeon are a respected Swiss manufacturer:
                        https://www.cousinsuk.com/product/bergeon-screwdriver-sets-static-stands
                        Russell
                        #700703
                        David George 1
                          @davidgeorge1
                          RS comonents have a great small set. only £9.55 and 3 years warranty.
                          RS PRO Phillips; Slotted Precision Screwdriver Set, 11-Piece
                          David
                          #700740
                          Bill Phinn
                            @billphinn90025
                            David
                            That RS set is currently £11.46, unless you’re VAT exempt. The same set, branded Kennedy, is currently £7.99 incl. VAT at Zoro. They were actually under £5 a few weeks ago. They may well go down again.
                            #700772
                            Harry Wilkes
                              @harrywilkes58467
                              Many thanks guy’s
                              H
                              #700778
                                I have a couple of nice sets, a double ended set like in the first post that’s branded Wickes and is very useful. I have a less diverse six-driver set with decent plastic handles and rotating caps branded Stanley that I keep handy as it does 90% of small jobs.
                                Both sets are good tough steel and stand up to use well, unlike the ubiquitous cheap ‘jewellers screwdrivers’.
                                Harry Wilkes
                                  @harrywilkes58467
                                  Thanks Neil
                                  H
                                  #700843
                                  Nick Clarke 3
                                    @nickclarke3
                                    Proops are still there but online (I can still remember the Nottingham Shop and poring over their catalogue as a teenager!)
                                    https://www.proopsbrothers.com
                                    #700901
                                    bernard towers
                                      @bernardtowers37738
                                      When my straight slot ones are worn/abused beyond repair I make new blades from pinion wire and it seems to work well.
                                      #700922
                                      Harry Wilkes
                                        @harrywilkes58467
                                        Thanks for the suggestion
                                        H
                                        #701343
                                        John Haine
                                          @johnhaine32865
                                          Nottingham?  I remember when Proops were in Tottenham Court Road!
                                          #701358
                                          roy entwistle
                                            @royentwistle24699
                                            Bernard     Darning needles make  good blades as well
                                            Roy
                                            #701359
                                            Matt T
                                              @mattt
                                              I can’t speak to their quality but my other half got me this set for Christmas. Hard to imagine a situation it won’t cover and it comes with a flexible extension that could come in handy (we’re observing polish Christmas this year so we got presents a day early :p)PXL_20231224_202417124PXL_20231224_202406881
                                              #701370
                                              Harry Wilkes
                                                @harrywilkes58467
                                                Thanks for your reply
                                                Happy Christmas
                                                H
                                                #701581
                                                Hollowpoint
                                                  @hollowpoint
                                                  I use precision screwdrivers a lot, I got tired of cheap cr*p so forked out for a comprehensive set of Wera micros. Expensive but worth every penny! 🙂
                                                  #701585
                                                  Russell Eberhardt
                                                    Yes, Tottenham Court Road, Earls Court Road, and Lisle Street were full of shops offering ex government electrical and mechanical equipment.  I used to spend hours browsing them in the 1960s.
                                                    Russell
                                                    #701587
                                                    Nicholas Farr
                                                      @nicholasfarr14254
                                                      Hi, I used to visit them fairly often in TCR, back in the 70’s, along with the likes of Z & I Aero Services, and G W Smith & Co (Radio) Ltd. and I would also pop along to Henry’s Radio in Edgeware Road. Ah! yes as Russell says Lisle Street was another favourite place.
                                                      Regards Nick.
