Mini Lathe Ways Lapping
Home Forums Manual machine tools Mini Lathe Ways Lapping
Viewing 15 posts - 1 through 15 (of 15 total)
  • #650440
    Russell Allsop
      @russellallsop49444
      Stripped the carriage of my VM210 mini lathe, re-assembled and shimmed the plates holding the carriage onto the ways. The carriage hits a high spot in the center of the ways, would lapping the ways with grinding paste be an option to level the ways to the carriage and is there a specific technique involved?
      Many thanks for your advise.
      Russell
      Russell Allsop
        @russellallsop49444
        Lapping the ways of the mini lathe
        #650443
        Nick Wheeler
          @nickwheeler
          If it's just one high spot, lower it with a scraper. You don't need the whole years of practice, tubs of engineers blue, fancy tool made from unicorn horn and 2000spots per inch deal, just a few strokes with whatever you have. I found all three of my tools benefitted from a few minutes of this, once use made such spots obvious.
          #650452
          Tony Pratt 1
            @tonypratt1
            Posted by Russell Allsop on 30/06/2023 11:55:51:
            Russell
            No
            Tony
            #650457
            Bazyle
              @bazyle
              Is it the top of the ways or the underside? Without the hold down plates is there any evidence of a high spot? You really don't want grinding paste anywhere near the bed and if there is a problem scaping may be a better solution,
              #650460
                Posted by Bazyle on 30/06/2023 13:18:14:
                Is it the top of the ways or the underside? Without the hold down plates is there any evidence of a high spot? …
                +1
                The plates holding the carriage on don't (I believe) contribute anything to a lathes accuracy. Cutting forces normally press the carriage down on the bed, so it's this interface that's has to operate smoothly and fit accurately.
                Underneath, the plates stop the carriage lifting off when something unusual happens, most likely an accident, or maybe a dig-in whilst parting off in reverse. The underside of the bed may not be machined accurately because the plates don't normally touch it. Reducing friction and allowing space for oil to get under the bearing surfaces are reasons for not clamping a carriage firmly to the bed.
                My guess is shimming has brought the holding plates into contact with a bulge in the roughly machined underside. Could be scraped off, but is it worth the bother?
                Presumably the shims have been installed because the carriage lifts. In what circumstances does that happen? There's a risk shimming is fixing the wrong problem, and it's whatever that causes the carriage to lift that needs attention.
                ega
                  @ega
                  Posted by SillyOldDuffer on 30/06/2023 13:47:17
                  Cutting forces normally press the carriage down on the bed, so it's this interface that's has to operate smoothly and fit accurately….
                  Yes, but what about using rear-mounted tools?
                  The shims under the Myford carriage are there for adjustment to a fit.
                  #650481
                    Posted by ega on 30/06/2023 14:28:40:
                    Could be except I don't think the VM210 mini-lathe has any way of rear-mounting tools. Unless the owner modifies the saddle himself. It's allowed!
                    not done it yet
                      @notdoneityet
                      I always lock down the carriage when parting off, so it is not very likely to be lifting during that operation?
                      #650491
                      ega
                        @ega
                        Posted by not done it yet on 30/06/2023 15:49:46:
                        That is no doubt good practice and I must try to remember to do it more often!
                        By way of contrast to the Myford, my slant bed lathe has the carriage lock at the front right but there is an adjustable keep under the rear (on the latter it is possible to run the lathe in reverse safely).
                        #650564
                        Pete Rimmer
                          @peterimmer30576
                          Russell
                          There is never a good reason to lap in machine ways. It's the exact opposite of what a moving way requires to be properly lubricated. You might (probably will) see an apparent improvement in function in the very short term but once done, wear will be highly accellerated.
                          It's a pretty good way to ruin a machine in short order.
                          #650860
                          Russell Allsop
                            @russellallsop49444
                            Thanks for the comments, in order to improve the rigidity of my mini lathe I'm trying to eliminate any play while still having free movement, based on your feedback I have slackened off the bolts holding the plates a tad, there is a small amount of play on the carriage now but the carriage moves freely across the ways.
                            #650865
                              Russell
                              I think it’s fair to say that the accumulated wisdom of the posts so far is:
                              Lapping is not the appropriate technique … But there is no harm in identifying specific ‘high spots’ and reducing them with a scraper.
                              Proceed gently and you should see some improvement … then quit whilst you’re winning !
                                Posted by Michael Gilligan on 03/07/2023 11:27:16:
                                Russell
                                Indeed, scraping is ideal as it leaves a finish that retains oil.
                                #651349
                                samuel heywood
                                  @samuelheywood23031
                                  FWIW my particular mini lathe carriage was loose @ headstock end & too tight to move @ tailstock end out the box.
                                  Measuring with a mike induced me to run a 4" file(.minus handle) along the lower ways on the bed towards the tailstock end.( what the saddle plates run on)
                                  It took a while,it's still not perfect, but carriage will traverse it's full movement without any looseness or overly tight spots……
                                  I'd leave the top of the bed well alone, unless i was a lot.lot more knowledgeable.
