mini lathe lever tailstock feed
Home Forums Model Engineer & Workshop mini lathe lever tailstock feed
  • #378928
    Anthony Knights
      @anthonyknights16741
      Reference the block that fits at the rear of the existing tailstock body, there appears to be no mention of the material used. I would have thought that mild steel or cast iron would be OK but in photo 2 it looks like brass.
      Am I correct in saying that the height of the block is 40.5mm?
      In fig 2 the threaded potion of the new lead screw looks longer than that on the original. I this correct?
      Anthony Knights
        queries
        #378934
          JS used mild steel on the original one.
          Ian S C
            @iansc
            I think some of JS's photos of steel bits came out brassy because of lighting, I think he mentioned that in one thread a few years ago.
            Ian S C
            #378952
            Michael Cox 1
              @michaelcox1
              The block is mild steel. I think it is clear in Photo 6 that it is not brass. If it looks brassy in Photo 2 then it is just a lighting effect.
              The block is 40 mm high. I seem to have omitted to include this dimension. My apologies for this omission.
              The dimensions of the new feedscrew are given in Fig 8.
              I hope this clarifies the drawing.
              #379052
              Anthony Knights
                Thank you gentlemen for your replies.
                #379054
                Anthony Knights
                  Thank you gentlemen for your replies. I hope to construct this shortly.
