Mini lathe improvements
Home Forums Model Engineer & Workshop Mini lathe improvements
  • #92012
    Clive Farrar
      @clivefarrar90441
      Hello guys I need some help quickly please as my wife is visiting ARC on Wednesady to get some spares and I want to be a comprehensive as possible.
      I followed the series on the mini lathe in mags 130 to 154 + and have the worshop series number 43 book.
      I have done most of the mods and have a good little machine.
      I have not yet done the handwhell / lead screw mod, that is next. I have the article that uses the M12 half nuts but I am sure there was a small " additional " 1/4 page alticle towards the end of the series that used flat thrust bearings to get rid of all the end float.
      I have skimmed through my mags and can not find it. Nor in any of the indexes I came across.
      I know its a long shot but does anyone know which one it is in ? or have i just been dreaming it.
      Regards Clive
      Clive Farrar
        @clivefarrar90441
        #92014
        NJH
          @njh
          There is an article in MEW 151 on adding a ball race to the mini-lathe top slide – is this what you seek?
          Norman
          #92042
          Clive Farrar
            @clivefarrar90441
            Thanks Norman, I know the one you meen and it uses 6900ZZ unfortunately that is not what i am looking for.
            The one I am after is the thrust bearings that go on the end of the lead screw at the same time as adding the extension shaft and hand wheel.
            Regards Clive
            #92044
            NJH
              @njh
              It might just be worth giving Ketan at ARC a call to see if he remembers. I will have a further trawl through my archive tomorrow if I get a chance.
              Norman
              #92060
              Clive Farrar
                @clivefarrar90441
                I,ve just had a nice cup of tea in the sunshine this morning and flipped through page by page 155 to current and it is not in there.
                Tonight i will work back from 154 rechecking each page.
                Thanks for your help Norman. I will check again before I start just in case you are lucky for me.
                regards Clive
