Posted by s d on 09/06/2023 06:30:56:
… I got essentially no error. 10.01mm over 10mm of travel.
Don't expect to consistently get that level of precision when actually cutting metal, due to tool wear, machinery flex, material flex, tool clamping shift, backlash, lathe bed aligmment etc etc.
Accuracy of the dials on the cross and top slides is a bit of a moot point in daily use. Even if you did have the original (disproved) 0.025 per 1mm error, you would not normally notice it in daily use in a home workshop. A 1mm deep cut is a roughing cut so 0.025mm error would not matter. Finishing cuts are taken at a depth circa 0.1mm to 0.02mm, so the error over that short distance would be immesureably small.
You will find once you get to know your lathe, you will not look at the dials much for roughing out. You know 1 turn of the handle is 1mm so that is near enough, or half a turn for half a mm etc. Then the dials come into play for the fine finishing cuts. Even then you usually need to measure between every cut and "sneak up" on the desired dimension.
