I thought I'd replied but perhaps I forget to hit send!
The gears ARE 8mm wide (7.8mm actually), but the plastic 80T are relieved around 0.75mm on one face (presumably to stop them rubbing) so they appear to be 7mm wide across the tooth. The small 20T are 8mm wide and steel.
They have a 4mm key not 3mm which is perhaps the only real defining feature between the Sieg and RealBull as Mike's mentioned.
Interestingly the shaft on which the gear and spacer sit on the leadscrew is too short but its closers to 15mm than 14mm (I was struggling to measure accurately with a steel rule)
I've made the gears Module 1 with a 20 deg pressure angle and nominal 0.075mm backlash/clearance and they mesh and fit nicely (better than the original gears which are a very close fit on the shaft and hard to remove!)
If anyone ever wants the 3D files for the gears or any of them printing, just let me know as I've got the design adjusted to accurately print to tolerance but this will only really apply to my printer, they're all slightly different (mine prints about -3% on internal holes and 0% external with the material and settings I use for function stressed parts)
I've got a 3D printed gear on my big 11" swing Myford as the primary gear and it's been running for 18 months now, so they are quite robust. I printed it in Nylon and being hygroscopic it was completely dry straight off the printer due to the temperatures (250c). I submerged it almost straight in ISO32 oil overnight hoping it would soak up that, rather than atmospheric moisture, seems to be doing very well, but I'm not sure if that's the oil dip or just generally because they're surprisingly durable. I might do a test next time because I would expect nylon to swell if absorbing moisture/oil as is normal for Nylon, so if submerged in oil straight off the printer, the bore should reduce in diameter if it's absorbed anything. The inside of the gear is slightly hollow so there's also room for it to retain quite a lot of oil if the air can escape.
Edited By Russ B on 01/05/2017 12:37:21
