Does anyone happen to know what the standard mini lathe toolpost is made of?
To this non expert eye it looks like it's not steel but some grade of cast iron?
Reason i ask is i want to make a new one to take up to 1/2" tools.
This will make the base thinner but not so thin, as due to my non informed & later more informed attempts to get the topslide working snug & smooth i've lost some height on the topslide. A 7/16" tool will almost fit to centre height as is.
The topslide does actually work quite well now!
The loss in base thickness will be offset somewhat by making it a two way toolpost, so there will be some additional side bracing not present on the original.
Material options are Ali (we can chuck that one out i think, ) , Steel, Cast iron, Or S.G Cast Iron.
Any thoughts? I'm thinking standard Cast Iron may not bare up too well the way i torque down the tool retaining bolts!
This will give the micro mill a good workout cutting the slots , but i'm not proposing to cut the slots full width in one.
Thanks.
