Thanks for all the responses, really appriciate it, I'll keep thinking about this tomorrow, it certainly sounds like a scroll saw is maybe not the best approach, at least not a budget one, I have seen some of the dual wheel version for around the £100-120 mark so maybe that's the way to go.
I had found and Erbauer saw for £99.99 from screwfix which has a flexi shaft, with a 100 piece accessory kit, full of mini sanding, grinding, and polishing bits and pieces, as well as an intergrated work light, a dust extraction point, and an adaptor to take plain blades as well as 2 pin (albeit a bit fiddly by the looks of it). I could really see the uses for one of those machines and its extras!!……. not that it would have any use for my needs right now – I'm just a bit of a tool lover.
IanT this jigsaw idea looks like something I'd like to get stuck in to, I'll have to have a closer look at how a scroll saw works, as I thought it was pretty much a jigsaw action – hence the Erbauer sounded up my street??
This above jig saw looks like it should be pretty easy to knock up, thanks for that – might hook a foot switch to mine though – dont trust myself – already to proud owner of a shredded thumb which after at least 10 years, still isnt right.
Thanks again for all these replies, really appriciate it!
