Milling Speeds for end mills
Home Forums Beginners questions Milling Speeds for end mills
Viewing 25 posts - 1 through 25 (of 33 total)
  • #10507
    Chris TickTock
      @christicktock
      Chris TickTock
        @christicktock
        Hi Guys,
        Have read contradictory advice over milling speeds for end mills. I should state I have a Sherline Mill
        Namely I have read:
        1. A bigger end mill can cope with higher speeds removing metal.
        2. RPM is approx the recommended 4 X CS (per metal) divided by size of cutter in inches.
        Nos. 2 then means increasing speed as cutter size is reduced, Nos. ! implies the opposite. Which is right here?
        I acknowledge carbon cutters can be run at higher speeds than HSS but as a generalisation is 1 or 2 my preferred mental guide as to RPM?
        Chris
        Edited to fix formatting only.
        Edited By SillyOldDuffer on 23/10/2020 11:23:25
        #502895
        Mick B1
          @mickb1
          No. 2 is correct in that surface speed at the periphery has to reduce as diameter increases.
          However, No. 1 can be correct in terms of volume per unit time of metal removal – providing the machine has the torque to achieve it, the mill and workholding have the strength to withstand it, and lubrication is adequate to prevent overheating.
          Those last three can require quite good mathematical capability to resolve and may require data that isn't easy to obtain – so they are often only accurately resolved in volume production operations where the manufacturing cost saving would justify the resource cost in time and expertise.
          #502898
          Emgee
            @emgee
            Chris
            In 1, are you confusing "volume of material removed" by a larger endmill with cutting speed ?
            A larger cutter will always win on volume of material removed provided adequate machine specs are suitable.
            Emgee
            #502901
            Martin Connelly
              @martinconnelly55370
              This thread is a good starting point for this topic it is reachable through the home page under workshop processes but here is the link for it. Thread 95687 cutting speed tables
              Martin C
              #502903
                Agree with Mick.
                Chris's first point is ambiguous: 'A bigger end mill can cope with higher speeds removing metal.' I'd restate it: 'A big cutter can remove metal faster than a small one.', which breaks the misleading link to 'speed' as used in No.2
                It's cutter speed over the metal in metres per second that matters. Surface speed depends on RPM and tool diameter. To get the same surface speed a small diameter cutter has to be rotated faster than a big one.
                May be a typo in Chris's Point 2 where he refers to Carbon Cutters running faster than HSS. Carbide Cutters can be run 5 to 20 times faster than HSS, not Carbon. Carbon Steel Cutters are run considerably slower than HSS and require careful attention to cooling because they can't take heat. These days most cutters are made of HSS, the obvious exceptions being Silver Steel, inexpensive taps and dies, and woodworking tools. (Which don't get hot!)
                Dave Halford
                  @davehalford22513
                  This (A bigger end mill can cope with higher speeds removing metal.) sounds like feed speed as they are stronger and able to take the extra depth of cut..
                  #502922
                  Chris TickTock
                    @christicktock
                    Thanks Guys,
                    All makes sense now. Nos 2 is correct. Nos 1 needs qualifying in terms of feed. If you were to feed a 1mm end mill too quickly it would not last long, especially if carbide (yes carbon was a typo). But that same 1mm carbide end mill needs higher speeds than say a 5mm.
                    Chris
                    #502951
                    Mick B1
                      @mickb1
                      Posted by SillyOldDuffer on 23/10/2020 11:21:25:
                      Agree with Mick.
                      No!
                      I was wrong!
                      It's not as I wrote: "…surface speed at the periphery has to reduce as diameter increases."
                      It's RPM that has to reduce in order to keep surface speed (unit length per unit time) at the periphery within working range.
                      Some of you will have noticed that. Sorry. Engineers are supposed to know what they're talking about.
                      blush
                      Edited By Mick B1 on 23/10/2020 15:30:48
                      #502957
                      Chris TickTock
                        @christicktock
                        Posted by Mick B1 on 23/10/2020 15:29:19:
                        Agree with Mick.
                        No!
                        I was wrong!
                        blush
                        Now I am confused how does this relate to RPM = (4 x CS) / Dia in inches.
                        I take it CS is peripheral speed for e.g. an end mills outer diameter. Anyone help on explaining Micks point.
                        Chris
                        #502958
                        Emgee
                          @emgee
                          I understood Mick to say in his 1st post rpm would have to be reduced to bring down the surface speed if using a larger cutter, although he didn't state rpm in his post, reducing the rpm reduces the surface speed at the cutter tip.
                          Emgee
                          #502960
                            Posted by Chris TickTock on 23/10/2020 16:01:27:
                            Chris
                            Just fill in the numbers and do the calculation.
                            Taking a cutting speed CS for steel as 100feet per minute we get
                            1/2" cutter
                            (4 x 100) / 0.5 = 400 / 0.5 = 800 rpm
                            1/4" cutter
                            (4 x 1000 / 0.25 = 400 / 0.25 = 1600 rpm
                            So from that you can see that to keep the materials cutting speed the same the RPM of a smaller cutter will be more than that of a larger cutter
                            For your 1mm cutter
                            (4 x 100) / 0.040" = 400 / 0.040 = 10,000rpm
                            Edited By JasonB on 23/10/2020 16:27:19
                            #502963
                            Chris TickTock
                              @christicktock
                              Posted by JasonB on 23/10/2020 16:24:08:
                              Chris
                              1/2" cutter
                              1/4" cutter
                              For your 1mm cutter
                              Nicely explained..thanks
                              Chris
                              #502966
                                As you seem to mostly work in metric you may find it easier to just do a metric calculation such as
                                CS / ( Pi x Cutter dia in meters) = rpm but use a metric cutting speed
                                For example a cutting speed for steel in metric would be 30m/min so using metric 12, 6 and 1mm cutters you get
                                30 / (3.142 x 0.012) = 30 / 0.038 = 796rpm for the 12mm cutter
                                30 / ( 3.142 x 0.006) = 30 / 0.018 = 1592rpm for the 6mm cutter
                                30 / 93.142 x 0.0010 = 30 / 0.003 = 10,000rpm for the 1mm cutter
                                Edited By JasonB on 23/10/2020 16:52:26
                                #502976
                                Chris TickTock
                                  @christicktock
                                  Posted by JasonB on 23/10/2020 16:51:30:
                                  Steady on Jason 10,000rpm on my Sherline??
                                  Chris
                                  #502984
                                  Roderick Jenkins
                                    @roderickjenkins93242
                                    Posted by Chris TickTock on 23/10/2020 17:22:39:
                                    Chris
                                    I've just changed the pulley on mine to give a maximum 10,000 rpm smiley
                                    Maximum end mill size on the Sherline is realistically 1/4" and for that I would run at your maximum speed all the time except when fly cutting.
                                    Stay well,
                                    Rod
                                    #502988
                                    Nick Wheeler
                                      @nickwheeler
                                      I wonder how many people are actually using their 12mm cutters at 800rpm?
                                      #502992
                                        That would depend on what cutting speed they chose to use for steel, it's quite a wide range, coatings or lack of would also determine speed . Type of cut would also comes into it as a full width cut is usually run slower than a side cut.
                                        #502998
                                        Dave S
                                          @daves59043
                                          Posted by Nicholas Wheeler 1 on 23/10/2020 18:26:13:
                                          IIRC I run mine at 560, as it’s the closest speed on my mill…
                                          Martin Connelly
                                            These recommended speeds are generally maximums for industrial use where time is money. For a tool material such as HSS they are the speeds at which you can expect overheating to occur which will reduce the working life of the cutting edge. It will not hurt the tool to be running below the recommended speed but there may be other issues such as the finish of the cut surface being poorer. For small cutters the biggest risk is that running them slowly requires a very slow feed rate to keep the chip load acceptable to avoid broken bits. Not too hard to achieve with well controlled motor drives or CNC but jerky hand wheel movements can snap a small cutter with ease.
                                            Martin C
                                            #503209
                                            Mick B1
                                              @mickb1
                                              I agree with Martin C – whether milling or turning I'm very often using speeds very much lower than maximum with HSS tooling, and you can, of course, still obtain very satisfactory finishes. Carbide demands much higher speeds in some situations – I'm less inclined to use it because I'm uncertain of its flexibility in that regard.
                                              I'm sorry if I raised doubts when I corrected my earlier posting – it simply occurred to me that my wording was unclear: if you maintain RPM constant, surface speed at the periphery would obviously increase with diameter; and it's surface speed you have to hold within limits, so to maintain that you must reduce RPM as diameter increases. I don't know how to make it any clearer.
                                              #503211
                                                I just gave a generic speed for "steel" using HSS to show Chris how the numbers work in the formula, Speed could have been anything from 50 to 150 feet per min ( 15-50m/min) depending on what steel and type of cut, type of cutter, any coating, etc as per my previous comment. If you take a look at the likes of Tubal Cain in Model Engineers Handbook he gives us 2000rpm for a 1/2" cutter in free cutting steel in which case 800rpm is a bit tamewink
                                                Treat published speeds as a starting point and adjust to suit machine and job in hand and as I tend to find with teh smaller machines they are best run towards the fast side but with reduced DOC and possibly feed to keep the motor in the sweet spot and to compensate for their lower rigidity.
                                                #503218
                                                mechman48
                                                  @mechman48
                                                  Have scanned pages from Tubal Cains 'Model Engineers Handbook edition 2' if it's of any help.
                                                  George
                                                  Edited By mechman48 on 24/10/2020 16:48:00
                                                  #505673
                                                  Zan
                                                    @zan
                                                    There’s fundamental problems with Tom’s tables in the past I have used them but i became exasperated with my copied tables until I realised the error
                                                    why? His speed for a 1/4” 4 tooth endmill is 960 in steel with 1 -3/4” feed , yet for a slot drill it lists 1600 rpm and a feed of 3” min. He has the headings the wrong way round! If you follow this point then the tables are very low in cut per tooth
                                                    using the 4*cs/ dia yields 1600 rpm ( cs= 100 fpm) Using a feed per tooth as recommended between 0.0005” and 0.002” this yields a feed rate of
                                                    fr= rpm x no of teeth x feed per tooth
                                                    = 1600*4* 0.001= 6.4 Inches per min.
                                                    Tom’s numbers are at the bottom of this range, and he states the tables came from Clarksons Autolock Chuck data.
                                                    with more modern spiral endmills with various coatings and the increasing use of carbide cutters in the home workshop, his tables aRe becoming outdated
                                                    Edited By Zan on 06/11/2020 21:25:40
                                                    #505685
                                                    Zan
                                                      @zan
                                                      Missed the link. Presto information in the “Counsellor” Pages 48 and 50
                                                      https://www.presto-tools.co.uk/Downloads
