I have milled both sides of a gunmetal casting (loco frame stretcher) and it is now very slightly curved (max deflection approx 1.5mm in middle of 100mm of total length). As the stretcher will carry valve guides I would like it as straight as possible.
Am I correct in thinking that if I return it to the mill vise, hammer it flat on parallels and then take another 'skim' off the convex side, this will relieve the internal stress and remove the bend?
Also, when milling off material for the above situation how much is enough? Obviously I don't want to take too much off end end up with a bend in the opposite direction. Or is it a case of take off 0.1mm remove check/repeat?
Any advice appreciated, Thanks.
