Milling Machine Wobbler engine
Home Forums Work In Progress and completed items Milling Machine Wobbler engine
  • #372701
    FMES
      @fmes
      This little project was completed for work, when someone made me a bet that I couldn't make a running engine using only a milling machine.
      Many of the apprentices made this successfully and goes to prove you don't always need a lathe to do the round bits.
      Please have a look at the album and when I get a couple I'll write up the build log.
      Edited By FMES on 22/09/2018 13:00:12
      Edited By JasonB on 22/09/2018 13:15:05
      FMES
        @fmes
        Building a simple oscillating engine using only the Mill and some hand tools.
        #372704
        not done it yet
          @notdoneityet
          Many older plans were provided for lathe-only users – as mills were not so common.
          I use my mills for more operations than my lathe.
          It’s a bit like woodwork where the router can be substituted for a saw, planer, drill – and likely more power tools.
          After all, a lathe can have a milling attachment fitted, just as a mill can be fitted with a rotary table…
          Did that particular project raise any special operations to make it with mill only?
          #372705
          FMES
            @fmes
            Posted by not done it yet on 22/09/2018 13:13:12:
            Not really, it was meant to show the apprentices methods of using different tools and accessories on the mill to get the job done.
            In our particular 'Training sceanario' we did't have access to a lathe
            #372706
            FMES
              @fmes
              Thanks for adding the pic Jason, I only wen't downstairs to make a brew and you beat me to it smiley
