Milling Machine Trammel
Home Forums Workshop Techniques Milling Machine Trammel
Viewing 22 posts - 26 through 47 (of 47 total)
  • #169621
    John Haine
      @johnhaine32865
      My point about float glass is YOU CAN CHECK IT! My lump is 9 x 12, a nice size to go on the mill table, when you rotate it around the axis of the spindle keeping the tram indicator still, you can hardly see the needle flicker. The thickness tolerance may be .13 mm but that will be all over thanks to Dr Einstein and the thickness doesn't affect the flatness. It may not be completely accurate, but I can determine its accuracy, and it was a sight better than Mr Myford managed when he set up my mill in his factory
      Fatgadgi
        @fatgadgi
        The problem with trammels, or anything else that fits in the chuck, is that they are limited in accuracy by the chuck. And my drill chucks can easily be a couple of thou out (try bunging a 6 inch silver steel bar in it and see what the run out is at the end) and different every time it's re-chucked.
        No, I'm an old fashioned bloke – I use a nice chunky bar to hold the dial gauge and proceed just like Tony, but without even the ground flat, just take the reading straight from the bed. If the dial gauge is rigidly held, the plunger can easily be lifted off the bed then rotated by twisting the chuck without changing the setting.
        But I did see that the toolmakers at our works use trammels and I suppose they should know, although it may just be to avoid the aching neck ……
        Will
        #169648
          I'll be a bit controversial here.
          The single gauge will always be spot on, but it is tedious.
          The dual gauge systems take a lot of effort to make, and and allow rapid setting, but there are two possible sources of error – first it can be no more accurate than the accuracy you make it with, second, it can be no more accurate than the chuck that holds it, and even collets aren't perfect with 4-6" of overhang.
          If , instead, the dials gauges are set using KWIL's /Eccentric's method of setting at a single point then they ought to be virtually as accurate as a single gauge. But, to be honest, as long as the contact patches are within a few mm of each other a set it when you use it trammel like this could be made of a couple of bits of wood nailed together and work just as well.
          I have an idea that a pivoting trammel with a pair of fixed probes and a single dial gauge to show if it is off horizontal, might work quite well.
          Vic
            @vic
            If I had access to a large lathe I'd get and old disc brake rotor (or something similar) and turn a nice smooth face on it and sized to my mill, firmly weld a nice chunky spigot on it and then return it to the lathe to turn the spigot true as in Johns post earlier. Once made it's mounted in the biggest collet you have and the Mill head is loosened. The knee is then raised until the "tool" is flat on the table without any movement. Head secured, job done.
            Another option is part of a nice large universal joint from something like a van. It should be quite accurate to start with but you'll need to turn a nice stub on it anyway to fit your collet. I gave up looking for one but I think VW vans might have something suitable. Guess it might need softening before it can be turned?
            I should add that after I thought of this some years ago a search on google provided a link to a company that actually makes small versions of this for modest mills like the X2. Do a google, I didn't bookmark the link. Let's call this "tool" a "Bell Trammel" for want of another name! Only a thought…
            #169724
            Anonymous
              Posted by John Haine on 14/11/2014 10:32:33:
              Float glass is dead flat and parallel, as you can check by spinning the plate whilst keeping the indicator still, the needle doesn't move.
              Sorry, but that is geometrically incorrect. If you spin, for example, a plano convex lens on the axis of the spindle you will get the same answer from the DTI, but the lens is neither flat nor parallel.
              #170049
              KWIL
                @kwil
                Of course if all else fails, you do it the old fashioned way, use a new cutter and watch how it cuts! secret
                #170058
                Mike Poole
                  @mikepoole82104
                  The procedure for setting up a dual clock tramming device is to zero both clocks on a common point, the accuracy of the collett or chuck becomes irrelevant unless clock tips really are miles out from a common point.
                  #170061
                  Chris Gunn
                    @chrisgunn36534
                    I know this will not help much but where did the phrase "out of tram" come from, surely the head or spindle is out of alignment or not square or not true?
                    Chris Gunn
                    #170062
                      Posted by Chris Gunn on 19/11/2014 14:47:39:
                      Chris Gunn
                      Quiote so, Chris
                      The phrase comes from the process of "trammelling" … which is [I suppose] a descriptive term for using a trammel.
                      Edit: Corrected typos and added link.
                      Edited By Michael Gilligan on 19/11/2014 15:22:16
                      #170071
                      Chris Gunn
                        @chrisgunn36534
                        Michael, when I was working, if I was trammelling, I was drawing a big circle.
                        Chris Gunn
                        #170073
                          Posted by Chris Gunn on 19/11/2014 16:13:14:
                          Chris Gunn
                          … which is exactly what these guys are doing; but with a DTI [or two] not a pencil.
                          Chris Gunn
                            @chrisgunn36534
                            It seems there is a lot of head realignment going on out there, probably due to the design of the Chinese vertical millers on the market. I recall that when I was doing my apprentiship using a variety of vertical millers, most of these had a vertical head that bolted to the machine column. The turret head as we know it now had not been invented then. The head could only be misaligned in one plane provided it was assembled nice and clean, but to align the head in the vertical position, a taper pin was provided to press into a reamed tapered hole drilled through the bolting flange into the machine column. The head would be fitted, the bolts nipped up, and the pin tapped in before finally tightening the binding screws. This would align the head perfectly in 30 seconds. The taper pin was threaded and a nut and washer fitted so it could be extracted when the head was moved or removed. It is possible that other holes were provided 90 degrees either side of vertical.
                            I do not have access to one of these millers so can only suggest that if there is space for a taper pin somewhere in the head mounting flange(s), the head should be properly aligned using the device of your choice, then it would not be a big job to drill and ream a standard tapered hole with a 1 in 50 taper reamer, and fit a threaded taper pin to ensure repeatable alignment without the use of any head realigning tool. If the head swivels in 2 planes, 2 pins could be installed. I was able to find a source of ready made threaded metric taper pins made for this purpose, but not imperial ones. I would have thought that this would make a good project for MEW.
                            Chris Gunn
                            #170112
                            Breva
                              @breva
                              A learners question If I may?
                              Is it the recommendation to tram the head absolutely flat?
                              I seem to recollect reading that there might be advantage in setting it a gnat's whisker one way or the other.
                              If so, which way and why?
                              Fatgadgi
                                @fatgadgi
                                Hi John
                                Yes you are right, tilting the head a gnats ensures that the cutter cuts on the leading edge only so that the trailing edge doesn't touch and spoil the surface finish.
                                I do sometimes do this but most of the time I keep the head square because setting work up setting up, for example with an edge finder is then not accurate and drilling holes, especially deep ones can be a problem.
                                cheers Will
                                #170124
                                Tony Pratt 1
                                  @tonypratt1
                                  In the real world just try and get the head as square [trammed] to the table as you can. You will still find that sometimes the tool will cut more on the front or back stroke even then.
                                  Tony
                                  #170134
                                  Eric Cox
                                    @ericcox50497
                                    If you tilt the head as you suggest then the gap between the trailing edge and the material will increase as the cutter diameter increases. Also you will only be able to take a cut in one direction only. .
                                    #170147
                                    Mike Poole
                                      @mikepoole82104
                                      I think we need to know how the machines we use actually perform, it is nice to believe the manufacturer made a workmanlike job of building your machine, but did he? Much has be written about setting lathes to turn parallel and face slightly concave, vertical mill tramming is also another regular. Most of the time perfection cannot be achieved but with a bit of effort we can be close. If we know what the magnitude and direction of the errors are we can work with this or even use it to advantage. The taper pin register is commonly used but it may be a shock to make a tram check and find that it is not spot on.
                                      Edited By Michael Poole on 20/11/2014 11:24:50
                                      #170212
                                      Breva
                                        @breva
                                        Thanks to all for the good advice.
                                        Will, that's a good point you make about drilling. I hadn't thought of that before. Setting the spindle dead square with the table, if that can be achieved, should be best. If the leading edge is cutting and removing the material the trailing edge should in theory have nothing to rub against as it passes over the cut surface. Probably if there is slight flex in the setup anywhere, the cutting edge may not remove all of the material, leaving a small raised amount for the trailing edge to rub on. This, when you think, is a good argument for having very sharp cutting edges and trying to remove as much flex as possible out of the mill.
                                        My own mill is an Amadeal 25 (like the WM18) and I am considering building a supporting beam of some sort, to dampen down the slight flex in the column. This is not a criticism of the mill. It will never be a threat to the Bridgeports but it's not bad and a little stiffening up couldn't hurt. I haven't seen a mod like this mentioned anywhere.
                                        KWIL
                                          @kwil
                                          As JS on here will confirm, even Bridgeports move.
                                          #170439
                                          KWIL
                                            @kwil
                                            Bogstandard,
                                            Who said anything about using the edges and curved effects on the surface to determine the setting, I was merely alluding to the visual of the cutting on the leading edge and watching the trailing edge.
                                            #170440
                                            Steve Withnell
                                              @stevewithnell34426
                                              The one thing that really surprised me when I bought my mill as a new starter, was how just how massive the cutting forces are – my mill is an old Warco Minor, it weighs about 145Kg on the bench and yet the size of cut that can be usefully taken with a 12mm cutter is (from a novice perspective) very small indeed. The limiting factor is not motor power, but just lack of rigidity, even though a 145Kg lump of cast iron supporting the cutter is hardly trivial.
                                              #170453
                                              Tony Pratt 1
                                                @tonypratt1
                                                Posted by Bogstandard2 on 23/11/2014 13:44:32:
                                                Posted by KWIL on 19/11/2014 11:54
                                                I flycut up to a couple of mm deep on most materials for rough cutting (Chester 836), but only ever use a minute cut to finish off, say 0.002mm, and that is when the crosshatch pattern should show itself after it has cut all the way across in both frontal and trailing cuts.
                                                Edited By Bogstandard2 on 23/11/2014 13:59:01
                                                Hi,
                                                I presume you mean .002" finishing cut ?wink
                                                Tony
