There's a lot of confusion over the various flavours of 30 and 40 taper tooling.
The difference between NMTB and ISO (aka INT or NT, technically DIN 2080) is that NMTB has an imperial drawbar thread (1/2" for 30 taper, 5/8" for 40 taper) and the other has metric (M12 for 30 taper, M16 for 40 taper). As far as I know, the Mercans use UNC (eg 1/2" 13tpi etc), whereas UK imperial tooling probably uses BSW (1/2" 12tpi).
The other flavours like BT, SK, CAT etc are intended for use with a pullstud, so have no parallel shank. However, if you have a manual drawbar, you could make a longer drawbar and use them instead of the ISO/NMTB style, potentially giving you more choice of toolholders. However, if you have a captive or power drawbar like me, you need to standardise on tooling style (including the thread).
You can buy new, good quality 40 taper tooling for £25 inc vat (or less) due to its popularity but 30 taper is more expensive and less easy to come by. But generally, metric is the norm over here, so I'd look out for ISO / INT / NT (DIN2080) rather than NMTB.
Murray
Edit – you'll notice that ISO40 tooling here is almost half the price of the (smaller) ISO30 equivalent and there is a larger choice of types and sizes.
Edited By Muzzer on 22/10/2017 14:23:19
