There was a discussion about coolant yesterday, here on MEW, plus lots of other posts about coolant systems. The same flood coolant system for lathes can be used on a mill.
I use a commercial tank and pump. Available from most lathe/mill equipment suppliers amd on ebay. Ample coolant supply to overflow the table if not throttled back. The tank has 2 compartments. Coolant return passes thru a strainer into the first compartment, then flows over a wall into the second to separate any swarf.
Paul
Universal Coolant Fluid Pump
- 240v Single Phase
- Flow Control Lever
- Magnetic Base Adjustable Nozzle
- Push Button Control
- 3 Pin Plug
Dimensions
- 11 Litre Tank
- 37 x 26 x 17cm
- IP54 Switch-plug combination
- Delivery Height 2.5m
- Delivery volume 3.5 Litres per minute
- 100w 240v Single Phase Pump
- Adjustable Flow Control Hose
Edited By Paul Lousick on 31/08/2021 13:01:04
