Mid-range is my watchword too! Beware chasing 'good quality' anything, because unless you're doing something special, the best is probably far more expensive than you need, and the costly quality could be useless, such as cutters carefully balanced to spin at 30000rpm, which is far beyond the ability of a 20VS.
I guess by 'good quality' you mean, 'lasts a reasonable amount of time before going blunt, not too easily bent, and I prefer not to put my daughters on the game to pay for it'. If so, see Jason's advice,
'Quality' and 'Disposable' both have ordinary English meanings likely to mislead in engineering. Jason's disposable cutters aren't disposable in the sense of being cheap and nasty, it's just that they aren't made to be resharpened. Which is fine for the average home workshop because hardly anyone has the kit needed to sharpen milling cutters. Disposables are popular in industry too, because you have to resharpen thousands of cutters to recover the cost of a suitable grinding machine, and below a certain level it's not worth the bother.
I bought an ordinary set of 2 and 4 flute TiN coated HSS cutters with my mill. They're neither Cheesium or sooper-dooper. With hindsight, I could have saved a few quid by only buying the sizes I actually use, and probably all of the 3-flute type! Though I eventually broke both 2 and 4mm cutters due to over-enthusiasm, all the others are still cutting fine. However, I use a 10mm solid carbide cutter for roughing out whenever possible, a fly cutter for flattening, and try to even wear out across the set, and the flutes. Apart from the Carbide cutter, there are a few other 'specials; the most common are uncoated disposables bought for Aluminium,
