Milling cutters
Milling cutters
Home Forums Beginners questions Milling cutters
  • #48997
    Dunc
      @dunc
      I own a machine similar to a Warco 18.
      Given that it can rotate the head 90 degrees it becomes a pseudo-horizontal mill.
      I appreciate that this setup would have neither the power or rigidity of a true horizontal machine but I wonder if it would be too much to use small side-and-face cutters? I have a source for new, top-of-the-line, hss cutters. If yes, some appropriate sizes?
      Mine has a M3 spindle and I have end mill holders for this mounting (for end mills). The milling cutters that I am considering would use a round shaft and keyway. Is there a standard(s) for these? What would I look for as an adaptor?
      One cutter I was considering was 1.5 inches diameter with a tooth thickness of 0.250 inches – in other words, a slitting saw that would cut a large slit.
      Dunc
        @dunc
        #48999
          Whats the bore of your cutters?
          A milling arbour should do the job, your size of cutter is no bigger than an involute gear cutter so should be doable
          Jason
          #49124
          Dunc
            @dunc
            Assorted bores- range from approx 0.75 inches to 1.5 inches (used a ruler so these are not to a thou). OD ranges from the one above. There was a plentiful supply so I didn’t purchase any until I could post and determine their suitability. Some are as above ( a wide slitting saw – perhaps it is a small slab cutter) while others are true side-and-face cutters.
            #49128
            mgj
              @mgj
              With the head rotated through 90 degrees, can you actually get the axis of the cutter close enough to the table?
              Chronos I think, and maybe others, do a right angle adaptor that fits certain mills with quills of particular diameter.
              However I question the need in most cases.  You take the same cutter and fit it conventionally and then cut along the side of the job – that will produce a keyway with a curved runout, rather than one with a radiused end, if that’s what is needed. I’d hold that in a dividing head and tailstock for convenience.
              I you want to start milling crankshafts and journals, that’s a slightly different matter, and going truly horizontal is more important, but for the odd keyway etc, is it worth disturbing a carefully set up head when it isn’t essential?
