This has happened a couple of times, but today ruined a part I was several hours into
The part was a 75x52x22 (mm) mild steel block stood upright in the vice.
The task was to remove to a depth of 10mm except for a spigot which would ultimately become a 6mm dia boss.
The machine is a VMR32L, A beefy thing for a hobby machine with R8 and a 1500W motor. Rigid enough that i can seriously consider climb milling with it.
MIlling cutter is a 10mm carbide running at full pelt (2200 rpm) – the cutter is a re-ground 'pro' cutter – possibly a little undersize because of it.
So I set the depth to 10mm an started taking 1mm – 1.5mm cuts. within a few passes I noticed that it was digging deeper on each pass so I stopped, tightened up the drawbar pretty tight and tried again.
Much the same thing happened, though with less creep this time. I ended up about 1.5mm too deep, so I'm going to have to junk the part.
The quill DRO showed little movement (around 2 thou).
The mill, by the way is not struggling with the cut and will quite happily cut this and more when there is no material at the bottom.
Am I expecting too much from this configuration? Should I be tightening harder? Would using R8 Collets give a better grip? I don't think there was oil in the collet / mill assembly, but could that be a contributor?
Looking forward to your answers.
Iain
