Thank you to all who have contributed comments – all have been much appreciated and made me think along different avenues. Sorry no response yesterday, it was such a nice day that I could put off no longer starting on the big list of outside jobs that I have been able to put off up to now because it was raining, or was too wet outside to work! So after a full day grafting, and an hour and a half in the shed I was fairly well bushed, but I had scored masses of brownie points with Senior Management so not a wasted day at all!
I have been trying to get my head around this feed rate bit. Working it out in my head in the bath, I came to see how a 1"/min feed rate at 360rpm with a 4 flute cutter gave approx 0.7thou/cut. A 4"/min feed rate therefore I reasoned at 360rpm would give approx 2.7thou/cut, a significant increase, but would that be too much? A 4"/min feed rate at 600rpm would give approx 1.67thou/cut – a half-way house. The thing is, I don't know what thou/cut rate I should be aiming for – what do you guys aim to achieve?
I also measured the sort of feed rate I was actually using when on power feed on the X axis and amazed myself by it coming out at 3-4"/min when machining down to near size, down to 1.5-2"/min when taking a finishing cut, so perhaps I am not that far out after all, it just sounded a lot! Mind you, that was measured without taking a cut and based on my memory of where I had set the variable speed control knob in the past. My 1"/min on feeding the Y axis was partly because I was doing it by hand, but I can see now that I wasn't being brave enough.
I also have been in the habit in the recent past of using a fair flood of coolant, both to cool the tool and clear the chips away a bit, and to achieve a better finish, or so it appeared to me to be. Using NeatCut Oil it has to be a fair flow otherwise there are too much in the way of fumes; a flood give no fumes, but is messy and clearing it away can be a problem. I did not use a coolant this time as every video I see of others milling there seems to be no coolant and I needed to see how the cutting would go. Perhaps I chose the wrong time for this.
I cannot give a picture of the chunks out the end of the cutter as the night before last, in a fit of pique, I proved to myself that there is no way I can sharpen an end mill, even a 16mm one, by hand on an off-hand grinder! It is now set aside to be my test piece for when I eventually get a tool and cutter grinder set up, for me to learn on on the basis that I could never make it worse. I do feel however, that the big chunks out the end were made as has been suggested above, by a chip getting caught under the mill. A couple of times I heard/felt a clunk, as if the cutter had hit a hard spot, plus saw a circle in the bit just cut, but neither time was I looking at the tool at that moment. Don't really want to name the source of the cutter as the firm is a reputable one with a good name have been of good service to me in the past.
I would also agree that perhaps although these column mills look sturdy and robust perhaps they look more rigid than they really are, and perhaps a 16mm end mill on steel is a step too far.
So, on reflexion and taking in the advice given above, I think I will try: a smaller diameter cutter, say 10mm until I get more experience on what works and what doesn't, use coolant whenever possible when on steel,and keep the feed rates up.
So, the major answer I could do with now, is what thou/cut should I be looking for to start with or be aiming for? I know a lot will depend on what the machine tells me, but a start point would be useful.
Chris
